Fan for SE? - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 20th March 2010, 02:04 PM   #1
royd55 is offline royd55  United States
Default Fan for SE?
Has anyone added a small fan to their simple SE? I did add vents to the enclosure, but seems like a lot heat anyway. I was thinking a small computer type fan.
Roy
Old 22nd March 2010, 03:40 PM   #2
neonthecat's Avatar
Roy
Hi Roy!
The case of my SSE gets fairly warm, but it's got enough vents in the top plate to keep the heat at a moderate level. A fan couldn't hurt, though.
I'm currently building Pete Millett's DCP-P, and with 8 tubes and 2 MOSFET's, I thought a fan would be a good idea. I used a tiny 12VDC fan mounted in the bottom plate of the chassis. It is powered by it's own 115/12vac xfmr and a diode bridge. The small fan is quiet, blowing around 6
CFM @ 3000 rpm. Should be more than adequate.
"We provide the music, you provide the silence." - Charles Mingus
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Do I want a fan? buliwyf Tubes / Valves 12 21st October 2005 10:58 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
fan kinser Everything Else 6 27th April 2004 10:09 AM
Copyright ©1999-2017 diyAudio
