Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th March 2010, 12:59 PM   #1
newtube is offline newtube  United Kingdom
Default surround amp as a pre?
Guys, i could be woefully off the mark here but. . .
Would it be possible for me to connect my marantz sr200 av amp up to the simple se as a pre-amp?
It has pre-out connections etc so looks like it would work, would i then have to run the av amp in stereo only?
Thanks,
Darran.
Old 9th March 2010, 01:25 PM   #2
Nikon1975 is offline Nikon1975  Austria
I have the same configuration with my Denon. When I listen music I put the pre in Stereo or Direct mode, normally I use the Denon for home theater, but if you set it up correctly as channel level, you could use it also in 5.1. The point is that you will have 8W on the front speakers and 100W (in my case) on the back speakers.
Old 9th March 2010, 02:10 PM   #3
Thanks nikon, just as i hoped.
surround amp as a pre?Hide this!Advertise here!
axial surround instead of radial surround Calvin Subwoofers 22 13th July 2009 07:46 PM
Blown amp pre-amp in or HU pre-amp out? scraph Car Audio 5 23rd January 2009 01:58 AM
Rotel surround pre = crap. dorkus Solid State 44 17th March 2004 09:44 PM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 03:01 PM
