Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 8th March 2010, 06:49 AM   #1
Default Lost in Translatio(or transformation) with Tubelab SE for 45
I am going to assemble a TubelabSE for 45, if I manage to support also 2A3, good, but I will stick with 5K OPT, just use 8ohm tap with 4 ohm speakers.
Anyway, my problem is the 6.3 CT. Here in Japan the transformers are either 0-2.5-6.3 V or 0-5-6.3 V. The alternative is to have a separate transformer for the filaments.
With whitch one I have better chance to succeed ? I was thinking to use schotky diodes for all the bridge, in case I use the 2.5 V tap. From my calculation it should work and reduce also heat generation in the regulator.
This has a technical reason, as with 100 V primary 6.3 V has an odd number of turns.
Best Regards,
Davide
Old 8th March 2010, 12:42 PM   #2
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I see what you are saying. You need 6.3V for the 5842 heaters, regardless, so you are stuck using that winding. You might be able to get by using the 5V tap and shorting R3.
Another alternative is to omit R3 and tie TI-3 to TI-4. Put he 2.5V winding across TI-5 and TI-7 like you are saying. Then you would use the 6.3 tap to power the 5842 heaters through the R3 pad. You could even use an external bridge and filter of you want to keep DC on those.
Old 8th March 2010, 11:51 PM   #3
Actually my idea was to connect the 2.5 and 6.3 V winding in the same way as it was center tap. Can't I ?
I assumend that a transformer 0-3.15-6.3 is a CT 6.3V. Am I correct ?
Thanks,
D.
Old 9th March 2010, 01:27 AM   #4
rknize's Avatar
Right. I'm not sure how that would work having uneven windings like that. It would create a strange ripple abd load one pair of diodes more than the other.
Old 9th March 2010, 08:13 AM   #5
But also with 0-3.15-6.3 you have a weird load configuration. I guess I have to try. worst case I will add a 6.3 1A for the drivers
Old 9th March 2010, 03:10 PM   #6
rknize's Avatar
Not really...0-3.15-6.3 is really 3.15-0-3.15 when you use the center tap as the ground reference. It's just is how you measure it. 0-5-6.3 is really 5-0-1.3 from that perspective.
Old 9th March 2010, 08:43 PM   #7
Guess I have to add a transformer for filaments :-(. I have already one, but I wanted to do one amp small and cute, small cabinet and iron. If I have to add a separate transformer, I will not resist to the temptation to support 2A3.
Thanks,
Davide
Old 9th March 2010, 08:49 PM   #8
rknize's Avatar
Look for a toroid that might fit under the hood.
Old 13th March 2010, 02:21 AM   #9
Maybe I habe found a solution: Silk can make a custom transformer with even double primary. Anyone have experience with Silk products ?
D.
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Tubelab SE with 45 tubes only operksoy Tubes / Valves 13 15th December 2009 06:16 PM
Tubelab SE 45... Super amp!? colivet Tubes / Valves 0 26th August 2008 11:38 AM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubes / Valves 14 27th November 2007 04:15 AM
WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 rick57 Swap Meet 0 8th November 2006 01:07 AM
Page generated in 0.09025 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
