Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 6th March 2010, 08:16 PM   #1
newtube is offline newtube  United Kingdom
Default LED power on light?
Hi guys, i built a simple se amp last year and i'm very happy with the whole thing. . .
However, i fitted a yellow led light into the front panel as a power on indicator but never got round to wiring it in, my question is how?
What do i wire the two leads to and is there a resistor needed etc?
Thanks.
Old 6th March 2010, 10:24 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
All depends what you want to wire it to. If it is a typical yellow LED, figure 2.2V @ 20mA or so. You can wire it to a 6.3VAC heater wiring using a 220 ohm resistor. It will flicker at 60Hz. If that bothers you, you'll need a low voltage DC supply of some kind.
Old 6th March 2010, 11:48 PM   #3
mtripoli is offline mtripoli  United States
If you can't tap from a DC point in the circuit and don't want the flicker use a full-wave bridge and a cap...(don't forget the led series resistor as well)... or, you could use a resistor and a dual color led (say red and green) wired in anti-parallel. It'll glow "yellow" on AC...
If you want to run off the line voltage (120VAC) use a 0.47uF, 200V cap in one leg of the AC line. Put a 1K resistor in the other AC leg. Use a 1N4004 (or such) diode wired in anti-parallel with the led. Put one leg of the AC on one side of the diode pair and the other AC leg on the other side of the diode. Still going to "flash" at 60 Hz (though you'll only see the flash if you wave your fingers in front of it or shake your head around while staring at it)...
Old 12th December 2015, 05:03 PM   #4
peraho is offline peraho  United States
Hi there-
I have a tubelab sse power indicator question, so I figured just add it to this old thread and keep it all together.
A friend and I are wrapping up our SSE builds, and he wanted to add a 6.3v pilot lamp from parts express as a power indicator, and I was going to do something similar with an LED.
Per Russ's advice above, for the 6.3v incandescent lamp my friend has, does that mean he just adds it into the two "T1-GRN" terminal blocks (one wire into each) on the board and that's it? I know this is a really simple question, but just wanted to double check before something explodes.
In my case, if I'm going the LED route, I use the same two terminals, but wire a 220 ohm resistor in series with the LED?
I just want to double check that with this sort of wiring, I'm using just terminal blocks, not connecting one end to the board and the other to ground or something. (This has been a great learning process, but still remember blowing up a multimeter back in high school...)
Thanks as always for the help!
Pete
Old 12th December 2015, 05:46 PM   #5
VictoriaGuy is offline VictoriaGuy  Canada
LED power on light?
Pete:
As far as I know, the answer to both your questions is :'Yes".
Wire the incandescent bulb across the heater supply, and do the same with an LED and a suitable dropping resistor.
A comment about some of the jewel-type indicator lights: I bought a bunch of new jewel light holders (imitations of the ones from the 50s & 60s) which use a #47 bulb- I can't rcall if I got them from PartsExpress or another supplier. The lamps in the new holders are shorter than the 'vintage' ones and it's almost impossible to remove the lamp ('push and turn') as it's buried in the holder. So my advice would be to check the lamp removal and insertion process before committing to a particular holder in an amp. BTW, I solved the problem with the jewel holder by replacing the lamp and lamp socket with a large LED and dropping resistor.
Old 12th December 2015, 06:09 PM   #6
tomchr is offline tomchr  Canada
tomchr's Avatar
When powering an LED from an AC source, beware that many LEDs cannot handle much reverse voltage. For example, my favourite red LED, the HLMP-D101, can only handle 5 V reverse voltage. A 6.3 V AC source imposes 8.9 V peak - a good 180 % of the rated absolute maximum.
To avoid excessive reverse voltage, use a diode such as 1N4148 or 1N400x in anti-parallel (i.e. anode of diode to cathode of LED) with the LED to limit the reverse voltage.
I usually run a standard red, green, or yellow LED at 5-10 mA. Going above that provides very little additional light. For low-current (high-efficiency) LEDs and blue LEDs, consult the data sheet for the LED.
Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 12th December 2015, 08:37 PM   #7
Thanks so much VictoriaGuy and Tom - exactly what I needed to know, and more...
Much appreciated.
Old 12th December 2015, 09:00 PM   #8
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
On my tube amps I always wire LED to B+.
This also gives indication that B+ is at a lethal voltage when you are working on it.
LED's require series resistor.
You can work out resistor by B+/0.01amps gives resistor value.
PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 12th December 2015, 11:07 PM   #9
LED power on light?
Originally Posted by VictoriaGuy View Post
A comment about some of the jewel-type indicator lights: I bought a bunch of new jewel light holders (imitations of the ones from the 50s & 60s) which use a #47 bulb- I can't recall if I got them from PartsExpress or another supplier. The lamps in the new holders are shorter than the 'vintage' ones and it's almost impossible to remove the lamp ('push and turn') as it's buried in the holder.
Here's a pic with the jewel holder with the supplied lamp and a 'vintage' (long) lamp to compare with the 'modern' replacement. You need very sticky fingers (Spiderman??) to remove the short lamp from the holder.
BTW, beware: some lamps being sold as #47 (at inflated prices) are not the long type but the shorter replacement.
Fortunately I have a good supply of lamps salvaged from old radio hi-fi gear. It's surprising how many of them still work, once the dust and tobacco tar are cleaned from them.
Old 12th December 2015, 11:13 PM   #10
LED power on light?
Interesting idea- what watt rating do you usually use on that dropping resistor? (Seems like a hefty resistor is needed for that little job?)
LED power on light?Hide this!Advertise here!
turned on Aleph 1.2,but LED doesn't Light up Steve Fay Pass Labs 13 27th November 2004 10:37 AM
LED light on car amp but no power up tristen Car Audio 4 22nd February 2004 04:09 PM
Copyright ©1999-2017 diyAudio
