Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th March 2010, 02:16 AM   #11
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
I find these folks to be pretty reasonable: https://www.surpluscenter.com/sort.a...c&keyword=EMRC I haven't purchased mail order, as I'm often in the neighborhood. I picked up 4 60uf pieces last time I was in town. They are cheaper than some other surplus places.
I'm not sure I should admit it, but my tube amp power supply is filled with motor runs that I bought as salvage from an appliance recyclers in Minnesota. They mostly came from air conditioners, and I figured there is no way an AC unit in MN can have enough hours to exceed the life span of the cap. They are still going strong, and I bought them (six in that supply if memory serves) for forty cents a pound. I still have a few kick around in a parts bin. If you've got a local appliance recycler and a sense of adventure, you might ask. $10 will buy a pretty large pile.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 5th March 2010, 08:04 AM   #12
MellowTone is offline MellowTone  Australia
MellowTone's Avatar
Originally Posted by nightanole View Post
How can you tell if its film or electrolytic?
Although you need to look at AC voltage, quality etc, you will have a fair idea by simply looking at the dimensions. If it is 50uF to 100uF and much smaller than 8cm high and 5cm across, it will probably be an electrolytic. That said, I wouldn't be buying from those who can't tell you brand, origin, ratings etc as it will cause you all sorts of trouble. Also, some may list Motor Start Caps as Motor Run Caps, be weary of this. A Motor Run Cap is designed for continuous operation, while a Motor Start Cap is only designed to be run for a few seconds at a time, to help turn power hungry electric motors over.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 5th March 2010, 08:35 AM   #13
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
oil filled = film
Mylar < 250 Vac > Polypropylene
Motor run caps?Hide this!Advertise here!
100uF Motor Run Caps i45one Parts 35 9th October 2017 09:28 PM
motor run caps grahamb Parts 3 17th September 2009 11:14 PM
Motor run Caps Question Fat Daddy Parts 4 3rd May 2008 10:55 PM
dual value motor run caps wicked1 Parts 4 6th February 2008 09:37 PM
ESR of motor-run caps? JoshK Parts 12 14th December 2007 03:17 AM
