Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 23rd February 2010, 12:44 PM   #1
Default Filament switching off in Tubelab SE
I have a strange problem with the filament regulator. From time to time it switches off.
At the beginning I thought it was a thermal problem, but now I have a big heatsink, that does not become hot at all, and also the chip is cold.
After the filament goes off, if I switch off and on the amp, then it runs for hours.
I have installed shotky diodes for all the four diodes, and the voltage on the transformer is 6.4 V. I tried to download the data-sheet of the regulator, but there is a broken link on the Sharp website.
Did you see a similar behavior ?
I understood that the regulator does not need to be electrically insulated from the sink, the diodes are. Am I right ?
Thanks,
Davide
Old 23rd February 2010, 04:01 PM   #2
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
One of the two chips needs to be isolated, yes. Are you powering 300Bs? I wouldn't expect the heatsink to be cold, regardless of how big it is. Is does sound like it is shutting down still. Are you sure there is good thermal conduction between the IC and the heatsink?
The only other shutdown scenario I can think of is a short. Could the tube filament be shorting in the tube or perhaps a short around the socket?
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
TubeLab SE, Finally Doc Jr 8156 Tubes / Valves 6 10th December 2009 03:21 PM
Tubelab SE input tube filament Evenharmonics Tubes / Valves 3 25th January 2009 12:10 AM
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
Switching power supply & filament Aiace Tubes / Valves 2 29th June 2004 12:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
