| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I think it's evident that the mentions of leaving B+ and DRV alone for off-board Power Drive, etc means that the 'normal' build jumpers these, but I want to make sure.
#2 |
All the best stuff comes from Chian
DRV_B+ gets a jumper, yes. I believe that you leave off this jumper if you want to isolate the FET drains from the B+ rail so that you can use them to drive a different pair of tubes running on an external B+ rail.
#3 | |
I had intended to provide the details for this build up, but from the emails I was receiving it became evident that the majority of people who wanted to built the 845SE had no business attempting an amplifier that ran on 1200 volts and costs nearly $1000. Several perspective builders had never built a tube amplifier before.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#4 |
#5 |
Is that right, Misster EpstEEn?
#6 |
Actually I would be very interested in using the board as a driver board. I was thinking of trying to use the 45 to drive the 300B. Would it work ?
D. |
#7 |
It can drive 300Bs directly in the on-board sockets....
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Tubelab SE w/Parafeed | smbrown | Tubes / Valves | 3 | 10th October 2009 06:34 PM |
| Tubelab SE in parallel? | Mazuki | Tubes / Valves | 31 | 20th February 2009 09:32 PM |
| tubelab se | DimZ | Tubelab | 58 | 20th January 2009 12:47 PM |
| Tubelab SE finished but need help. | Evenharmonics | Tubes / Valves | 50 | 8th July 2008 06:04 PM |
| Page generated in 0.07481 seconds (100.00% PHP - 0% MySQL) with 9 queries |
