Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th February 2010, 05:05 AM   #1
Nikon1975 is offline Nikon1975  Austria
Default Tubelab SE for other tubes
I like the Tubelab SE very much !! I don't know if it's the power drive, or the choice of good driver tubes, but it sound good.
Now, can I try to use the same board with other tubes, like KT88, and this family?
The idea is:
1) The heaters will have external power, AC, DC, elevated...to be decided
2) The cathode connected to the cathode
3) The grid connected to the grid.
4) The screen connected in triode or UL mode.
I'll put a B+ around 400 V, Caps rated 450V and coupling caps rated 600V
What else should be changed ?
What other triodes can be used (and would be worth useing) with minor modifications ?
Old 16th February 2010, 05:52 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I've tried those types of tubes in my TSE. They work fine. Just power the heaters from the raw 6.3VAC from the transformer. I used the 300B B+ mode, which is around 390V. I tried it with EL34s and KT90s. I didn't listen to it long like this. The final chassis will let me try these and other tube types (like sweep tubes) with ease.
Tubelab SE for other tubesHide this!Advertise here!
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
Tweaking the Tubelab SE Nikon1975 Tubelab 10 4th February 2010 03:58 PM
Tubelab SE with 45 tubes only operksoy Tubelab 13 15th December 2009 06:16 PM
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
Tubelab SE finished but need help. Evenharmonics Tubelab 50 8th July 2008 06:04 PM
