Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 14th February 2010, 11:13 PM   #1
neonthecat's Avatar
Default SSE grounding question
Hello to all....
This is my first post as I have a SSE board on the way. In preparation, I've been studying the George's website and the SSE schematic and wiring diagrams.
I noted that the main power ground goes from the IEC socket, to the RCA input jack (non-signal side). The RCA jacks I'm going to use have insulating washers to isolate the entire RCA jack from the chassis ground. The last amp I built did not ground the jacks to the chassis.
So my question is if this grounding method will cause any hum problems? Would it be better to supply the board (and chassis) a ground directly from the IEC socket, and let the RCA's stay isolated?
Thanks!
"The Cat"
Old 14th February 2010, 11:56 PM   #2
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
That is exactly what I did and it works fine. The key is just to make sure you have only one path between the PCB and the chassis.
Old 15th February 2010, 12:35 AM   #3
neonthecat's Avatar
Russ,
Thank you for the reply.
BTW....Your SSE build looks great. I hope to post some shots of my own in due time.
Old 12th September 2010, 10:01 AM   #4
I was just looking at RCA plugs and wondering the same thing. The hours I've spent sifting through and searching posts here has been very worth while. All my board parts have been ordered so I'm starting to look at sourcing chassis mounted parts.
Some more beginners questions about SSE urmoo Tubelab 16 12th February 2010 06:19 PM
Grounding Question bigbillc Pass Labs 25 2nd January 2010 01:00 AM
Throw it on the heap... SSE JdJ Tubes / Valves 8 30th December 2009 10:29 PM
Tubelab SSE measurements budmaestro Tubelab 8 24th June 2009 11:41 PM
grounding question skyraider Chip Amps 1 9th March 2004 09:12 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
