before i drill Simple SE Chassis Seperation of input and output - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th February 2010, 02:41 AM   #1
saletel is offline saletel  United States
Default before i drill Simple SE Chassis Seperation of input and output
so this is a 12x10x2 chassis
(board is inverted layout upside down for visualization)
was wondering how influence the motor run cap would have on input noise assuming i run the input wiring down the right side of the chassis.
should i swap the cap with the opts? the simple se layout says to keep the outputs and the input seperated and this would put them pretty close together.
or should i redo the layout all together? thanks for the input.
Old 4th February 2010, 04:39 AM   #2
chrish is offline chrish  Australia
chrish's Avatar
The only way I can see it fitting reasonably would be:
Rotate output transformers 90 degrees. Move them to the top right as shown in your picture.
Rotate power transformer 90 degrees. Move to top left corner as shown on photo.
Rotate choke 90 degrees and leave in place.
Place cap between choke and power transformer.
Hey, look at my avatar, kinda like that ;-)
Old 4th February 2010, 04:42 AM   #3
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Or at the very least put the cap in the upper, left.
Old 4th February 2010, 04:43 AM   #4
It is kind of hard to see but here is how my Simple SE was positioned. Like chrish said rotate the OPT and rotate the power tranny and move the cap over.
Doing it this way I found I didn't have to use much wire at all.
Old 4th February 2010, 07:49 PM   #5
Ty_Bower's Avatar
If I were building on that chassis, I'd probably do a layout similar to what Nic suggests. I might put the PT in the back and the can cap near the front, but I suppose it doesn't make much difference either way.
http://i69.photobucket.com/albums/i4...leSErev22a.gif
Old 4th February 2010, 08:01 PM   #6
rknize's Avatar
Here was the layout I was pondering before ditching the 12x10 and building my own chassis:
Old 4th February 2010, 08:29 PM   #7
tomchr is offline tomchr  Canada
tomchr's Avatar
I'm curious here... What's that eye on the left of the volume control?
~Tom
Old 4th February 2010, 09:10 PM   #8
Oh it was the power switch. Not really sure why I thought mounting it like that would be a good idea but that is what I did lol. One of those late night ideas that turn out how I thought it would. Oh well I didn't feel like redoing the front panel because of the switch.
Old 4th February 2010, 11:43 PM   #9
BillEpstein's Avatar
I like them wide open spaces, 10x17x5. Save that little condo for a phono stage or something.
input sensitivity for Tube Lab Simple SE Salsero Tubelab 5 19th April 2013 11:20 PM
Input impedance of tubelab simple se pforeman Tubelab 1 24th May 2009 12:42 PM
Input impedance of tubelab simple se pforeman Full Range 2 24th May 2009 05:10 AM
Input impedance for Simple SE? jrn77478 Tubelab 1 16th January 2009 04:47 PM
What do you guys use to drill holes on chassis?? jamesjung21 Tubes / Valves 48 15th May 2005 08:21 AM
Copyright 1999-2017 diyAudio
