Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 26th January 2010, 11:19 AM   #1
BillEpstein's Avatar
Default 120k resistor question in SE
Looking at the schematic to see if there are any critical values for the 1/4 and 2 watt 120 k's I see that there are other values for R8, R13, etc.
I only have 110k on hand which are within 10% but do any of these have really critical, say 1%, values?
Old 26th January 2010, 02:09 PM   #2
tubelab.com's Avatar
None of those values are particularly critical. The larger wattage resistors do dissipate some power and should not be substituted with a smaller wattage resistor. R8 and R19 are wired directly across the input. These should be a high quality resistor since cheap resistors may introduce noise. The value is not at all critical and anything from 100K to 330K should work.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 26th January 2010, 03:27 PM   #3
Thanks, George, and 1 more on R6, the 10k 5 watt. I have a 5 watt Mills there that looks about the same size as a 2 watt Kiwame, and I've read it runs really hot. I had trouble with bigger Mills in my other 45 amp and wonder if, like I did there, a 20 watt aluminum housed is necessary?
Old 26th January 2010, 04:27 PM   #4
rknize is offline rknize  United States
Glass is made from sand.
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Depending on your B+...5W is pushing it. I went with a 7W here and it is probably one of the hottest components on the PCB when I am running 300B voltages. I picked up a aluminum housed 10W to mount to the chassis when the time comes.
Replacing the cathode resistor with a current source in SE ? 2wo Tubes / Valves 12 6th November 2009 02:31 AM
simple se cathode resistor question pforeman Tubes / Valves 4 1st June 2009 06:08 PM
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 05:11 PM
brown alps pot replacement?120k can i use 50 k to replace it homertooties Solid State 2 8th December 2006 07:12 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 06:36 PM
Page generated in 0.08785 seconds (78.32% PHP - 21.68% MySQL) with 10 queries
