Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 30th January 2010, 07:46 PM   #11
SGregory is offline SGregory  United States
Default Filament Heat Sink Alternative
Here is another possibility. I know George didn't have much luck bending the 5pin regulator leads, but it can be done carefully. In the attached photo I had an extra heat sink laying around so I cut through the top plate and exposed it. It is electrically isolated with mica and grease. The sink is bonded to chasis ground in case the insulators break down.
For the FETS and CCS I used 1/8th inch plate similar to rknize. The key is to have some airflow in the chasis. Otherwise, as I found out, the FETS WILL die.
Living Life Doing the Waltz in 4/4 meter.
Old 30th January 2010, 10:35 PM   #12
BillEpstein is offline BillEpstein  United States
BillEpstein's Avatar
I hope you aren't planning to mount the PCB upside down. The tube sockets will have their pins swapped. It won't matter for the heater, but having the grid and plate pins swapped will be bad.
OK, between your last post and finally placing sockets and tubes on the board, I get it. I had the wild-eyed idea of wiring the sockets because I have this phobia about amps whose sockets are so buried it's necessary to grasp the tube by the bulb.
1 1/4" stand-offs will expose the bases of all but the 9-pins and those are much tougher IME than the big guys.
Thanks for that!
Old 31st January 2010, 12:22 AM   #13
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Use a "socket saver" to boost the height od the 9 pin tubes.
AES (Antique Electronic Supply) # P-ST9-900
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 31st January 2010, 01:37 AM   #14
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Ditto...you can see them in the pic I posted earlier. You can even take them apart and splice a grid stopper resistor into the appropriate pin, if you are super-paranoid.
Old 3rd February 2010, 02:08 PM   #15
Nikon1975 is offline Nikon1975  Austria
Just for the records, I measured the temperature of the heat sinks with a thermocouple.
The mosfet are at 110 C and the CCS at 90 C, with the standard heat sink. The probe was between the two and the board is working without chassis.
I don't think is a goos idea to have them under the board. :-(
D.
Old 3rd February 2010, 02:40 PM   #16
rknize's Avatar
Not without pulling the heat away from the area with a large heat sink of some sort, no. Sounds similar to the measurements I made with the same setup. I ended up putting them back on top after playing around with the chassis design, though either way would have been fine, thermally.
Tubelab SE inverted assemblyHide this!Advertise here!
Tubelab SE vs Simple SE Pez Tubelab 25 29th October 2011 02:16 AM
46 and the Tubelab SE w5jag Tubelab 8 18th May 2009 07:52 PM
tubelab se DimZ Tubelab 58 20th January 2009 12:47 PM
Tubelab SE finished but need help. Evenharmonics Tubelab 50 8th July 2008 06:04 PM
Tubelab SE ... which 5AR4 ? lowtherdream Tubelab 4 19th June 2008 06:22 AM
