| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
Is there anything that should be changed in the stock circuit when running it with a preamp? Using either solid state or tube.
#2 |
Tubie Noobie
Nope. Just watch if your preamp has alot of gain that you are not clipping the amp when trying to play it louder.
If it is permanent then you could eliminate the volume pot, not required though. I like to use my preamp with the SSE using CFB. I get the gainback.
Living Life Doing the Waltz in 4/4 meter. |
#3 |
Sounds good! I have no volume pot and always use it with a preamp. I have a tube pre that is uses a 6dj8 and a 6ns7 but it has to much gain about 1 click on the alps 50k pot and she is to loud. Need to do some looking into on that. Thanks
#4 |
The SSE has a plenty of gain, so a pre is not needed to put the amp into clipping from typical "line level" sources. How much gain does your preamp have?
#5 |
Can the current source at the input tube anode be replaced by a resistor if the gain is to high?
Will it affect performance (other than PSRR) compared to CCS? |
#6 |
That would reduce the gain. How much depends on what operating point you choose.
#7 |
I have a high-gain tube preamp that I like, so I built the Simple SE without a volume pot and used a JJ ecc99 / 12bh7 driver tube. It has a lot less gain than the at7. I posted about it in a thread about driver tubes in this forum.
#8 |
Hi all,
I am a little confused about the lowering the gain on my simple se. I am using a 26 DHT pre amp, and finding the gain too high on the SSE. What input valves can i drop in place to lower the gain, and any components i need to change on the PCB? Is the 12bh7 such a tube? Thanks Ian |
#9 |
12BH7 is a suitable substitute, but it requires a different set point on the CSS to operate it in its most linear region.
Russ |
#10 |
| Tubelab SE vs Simple SE | Pez | Tubelab | 25 | 29th October 2011 02:16 AM |
| Another Simple SE builder | Ty_Bower | Tubelab | 118 | 29th November 2010 02:34 AM |
| Simple Simple SE questions | nodiak | Tubelab | 57 | 2nd February 2010 11:02 PM |
| Simple SE with 807? | dogfish | Tubes / Valves | 19 | 24th September 2009 04:23 AM |
| simple se success! | newtube | Tubes / Valves | 3 | 24th May 2009 09:23 PM |
| Page generated in 0.09159 seconds (78.67% PHP - 21.33% MySQL) with 10 queries |
