GLY513 in PS of Simple SE / PP and OTL - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th January 2010, 01:10 AM   #1
Default GLY513 in PS of Simple SE / PP and OTL
I just bought 6 GLY513 600uf caps from a guy on EBAY that I want to try as output caps in a 6as7 OTL amp I am slowly buying parts for. As that would only need 2 -- I got 4 extras. Could I use one in the PSs of the Simple SE and or Simple PP (planning to build both)? What are the tradeoffs? Is it worth it? Could I use an SS rectifier only with them, would there be some clever way to make use of it with a tube rec, or was I just plain crazy to buy these things at all (kinda scary ). Give it to me straight doc. thx.
Old 12th January 2010, 01:57 AM   #2
Tubelab_com's Avatar
was I just crazy to buy these things at all (kinda scary ) thx.
I don't know, I bought 6 of them too! I got them with the power supply of a really big push pull amp in mind, but I have wired one into several of my experiments. I often connect one across my old Fluke 407D power supply to supress its inherent instability when overloaded (like I would do that!)
I have connected them into both amps. 600uF is a big grunt for a rectifier tube to charge up. I seem to have found an indestructable 5AR4 (I haven't killed it in 4 years of testing), but you may have issues with some of the current production tubes.
If using one in a simple SE, I would reduce the first capacitor to a small value, something like 10 uF, use a fairly large choke (not the resistor), and install one or more inrush current limiters. I have several different flavors of inrush limiters on order, so I will have a repore on which ones, and where to connect them in the near future.
I have connected one into my 6CW5 version of the Simple P-P which uses solid state rectification. No modifications were needed. I haven't tried it on the EL84 version yet.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 12th January 2010, 01:59 AM   #3
Ty_Bower's Avatar
I'll vote for the "crazy" option. I'm glad he ships these with shorting jumpers across the terminals.
Old 12th January 2010, 02:14 AM   #4
And how would you know this, unless you were slightly crazy too.
OK, since we are all a bit warped, I will urge you to resist the temptation to spark one of these out with a small screwdriver, if you value your screwdriver. It makes a bigger bang than a 2400 uF 450 V electrolytic.
Old 12th January 2010, 02:44 AM   #5
I was looking to replace caps c10 c12 c20 c22 these in hopes of creating a electrolyticless Simple SE. No real particular reason for doing this I just wanted to make mine a bit more unique. I cut the bolts off the top of the GLY513's with a hacksaw then polished the tops. This amplifier is F---'n big. The other four capacitors are motor runs that replace the on board electrolytics. They are rated at 370vac which I believe my B+ of 450vdc should be with in limits. I still haven't finished it so if anyone thinks I am ridiculous speak now or forever hold your peace.
Old 12th January 2010, 03:11 AM   #6
I don't think it is ridiculous, I want to know how it sounds.
Old 12th January 2010, 06:52 PM   #7
Wow -- more than I could ask for Tubelab -- thanks loads. I got some CL-90s as your page suggests - also found some cheap CL-190s. I have several NOS 5U4 rects (also found some 5Z4 and 5V4s too) -- should I try them? All my 5ar4s are reissues -- NOS are too $!$!$! .
VERRRRRY COOL - I also have some 6CW5s which I swap out on my AX84 guitar amp. Nice to know they will work too (ultimately woulda figgered it out I guess but will take some of the fear/fun out of turning it on ). I really like the sound of PP 6CZ5/6DT5/6CM6 types too (but mo deffernt than 6CW5s fer sure - need paralleled sockets fer dem) -- gee maybe half-n-half (did I mention I'm crazy )
Oh yeah -- one more thing - I doan do the screwdriver thing - probably should do it once I guess just to say I did (got started on this stuff too old I guess.) Anywho - my cap drainer uses a cement 30ohm 10 watter. Should I get a higher wattage resistor for these beast capacitors?? thx.
Old 12th January 2010, 10:18 PM   #8
Can I ask your source for these other 4 other motor runs (2x22uf and 2x50 or60uf I presume)? All I can find are oblong ones that doan look as good as these round ones.
Just so I understand -- you are downgrading from 4 1500ufs to 600uf right?
Wow -- go for it! I am also very interested to hear about the sound. I have not bought the lytics yet for this dude (I hate them so I always put it off till last).
Old 12th January 2010, 11:06 PM   #9
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The rounds ones are harder to find, but they are there. I bought a bunch of different ones over the past couple of years...just gotta keep looking.
Somehow I ended up with 9 of those GLY513s.
Old 13th January 2010, 01:06 AM   #10
Do NOT put 6CW5's in an amp designed for an EL84. They will have a short unhappy life, and the resulting fireworks may blow up something else.
The Simple P-P is designed so that you can build a 6CW5 version, or an EL84 - 6BQ5 version. They are not the same, and different transformers are required. A 6CW5 runs on a much lower voltage than an EL84 and draws a lot more current. So much current that a 5AR4 or any other popular rectifier tube, can not run a stereo amp. Solid state rectifiers are required.
A 30 ohm resistor will draw about 15 amps when connected across 450 volts. That is 5000+ watts for a brief instant. Ordinarilly the cap would discharge so quickly that the 450 volts is gone before the resistor gets hot. These guys may change that. Your resistor might explode. I have seen the white ceramic and cement ones explode. I have a 500 ohm 20 watt resistor, and it gets hot when I touch it to one of these caps, but it does safely discharge it. It is a big old black glass coated resistor. It still sees a 500 watt overload for about 1/2 a second. That might still kill a cheap Chinese resistor.
Otl Se liberty Tubes / Valves 15 10th July 2006 05:38 PM
OTL PS question!! satelitis Tubes / Valves 23 19th November 2004 04:17 AM
se otl Andrewbee Tubes / Valves 7 23rd August 2004 07:08 PM
A simple OTL?? Magura Tubes / Valves 35 16th February 2004 03:26 AM
Possible to make a KT88 PP UL schemat OTL ? Layberinthius Tubes / Valves 3 5th February 2004 02:59 PM
Copyright ©1999-2017 diyAudio
