Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 11th January 2010, 05:34 PM   #1
urmoo is offline urmoo  Estonia
urmoo's Avatar
Default Some more beginners questions about SSE
Seems, that it is not possible to edit earlier posts, so I start here new one with a bit wider subject.
Supplemental capacitor, is it OK to use 300 uF 400V cap? Another thing, probably stupid question- is it possible, that using supplemental cap improves signiffically sound quality? I could swear there is mutch more bass than earlier, without this cap...
STB switch is installed, lets see, if it will blow away rect. , for now everithing is OK.
Old 11th January 2010, 07:44 PM   #2
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
300uF is quite large. Is this an electrolytic cap? If it is rated for 400V *AC* line use, then it should be fine up to 560VDC or so. If it is just a normal 300uF 400V cap, then you are pushing the limit (depending on your actual B+, of course).
I found the putting a nice big film cap there made mine more "punchy" as well.
Old 11th January 2010, 08:42 PM   #3
urmoo's Avatar
Yes, It is electrolytic cap, marked as 400WV 300uF with +/- polarity. B+ is actually around 450-460V, so not so good for cap, I guess... If it works near limits, should it warm up or is there other symptoms I should look for? Is 300uF OK, or will it start to give me somekind of troubles?
Old 11th January 2010, 09:09 PM   #4
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
The only concern I would have regarding a large capacitor would be the current rush at power on if you are using solid state rectification. A CL-90 thermistor should help there. Otherwise tube rectification should provide a soft enough start.
Correction: If you B+ is 450v your capacitor should be rated for 500v to be safe. If your running with 400v caps with 450v I'd expect cap life to be minutes and not hours.
Old 12th January 2010, 01:52 AM   #5
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
As I recently found out, sometimes the first indication that something is wrong is a BANG! A capacitor that big stores a lot of energy if it developed an internal short, it could explode rather violently. I would recommend disconnecting it immediately. See post #149 in this thread:
http://www.diyaudio.com/forums/tubes...mp-design.html
300 uF may make life difficult for your rectifier tube. I would look for something close to 100 uF. If it is intended for DC voltage it should be rated for 500 volts or more. If it is an AC cap it should be rated for 370 VAC or more.
If you happen to have two of your 300 uF 400 V caps they can be wired in series to make a 150 uF 800 V cap. Put a 100K to 470K resistor in parallel with each cap to equalize the voltage.
That is the reason that I recommend their use. It lowers the effective impedance of the power supply, so that more of your sound energy goes toward the speakers instead of going back into the power supply. I have found that a polypropelyne film (motor run) cap works better than a big electrolytic in this regard.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 12th January 2010, 10:24 AM   #6
urmoo's Avatar
Thank you for your replys! Your answers are proof, that If you dont know exactly what you are doing, then its better to ask for a advice Cap is disconnected and I will go to search for another one.
Old 12th January 2010, 06:04 PM   #7
urmoo's Avatar
Just to be on the safe side- does the connections look like this?
Old 13th January 2010, 01:18 AM   #8
Yes, thats right
Old 13th January 2010, 04:01 PM   #9
urmoo's Avatar
Thank you for saving me from explosion Now caps are installed, and as result the sound is unbelieveably improved- excellent got even better! To be a rookie has some advantages- so many things can surprise
One more question. I use CFB pretty seldom, but today, after finishing installation of caps, I tested all functions of amp. Everything was OK, except CFT- switcing ON and OFF does not make any difference. I checked wires and solderings, they seem to be OK. Bad thing is, that since last time I used CFB I have done some replacements (Volume pot), then 5AR4 started to arch- short connection somewhere (dissapeared after disconnecting and connecting wires) and I have no slightest idea when CFB dissapeared (or perhaps it is constantly ON?). Is there any simple way to find out where CFB gets lost? I have a multimeter and dont affraid to use it
Old 19th January 2010, 08:56 AM   #10
urmoo's Avatar
Hmmm, OK, I will try to rephrase the question. Is it possible, that CFB has gone because some el. components are blown up (C12 and C22 for example)? If yes, how to check?
Some more beginners questions about SSEHide this!Advertise here!
TAS5518-8182 project beginners questions please help velicko Class D 3 5th October 2011 02:56 PM
Throw it on the heap... SSE JdJ Tubelab 8 30th December 2009 11:29 PM
Tubelab SSE inrush current limiters. syyma Tubelab 9 28th August 2009 09:31 PM
Tubelab SSE measurements budmaestro Tubelab 8 25th June 2009 12:41 AM
Tubelab sse transformer wires newtube Tubelab 9 12th May 2009 02:29 PM
