Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 9th January 2010, 10:10 PM   #1
royd55 is offline royd55  United States
Default The simple PP
I have seen a lot of interest in the simple pp. I would like to know why this particular amp has attracted so much interest. What makes this amp special? I just don't know enough about amps to venture a guess about this.
Roy
Old 10th January 2010, 06:58 AM   #2
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The amp circuit itself it fairly classic in design. I'd say the hoopla is more about George's reputation than about the amp design itself. All the fine-tuning is done and the kit should be accompanied by a nice set of instructions. The chances of excellent results are very high. Little worry about grounding or anything like that because it's all on one PCB.
There are probably a lot of happy Simple SE owners that are itching for more power, too.
Old 10th January 2010, 07:12 AM   #3
Geek's Avatar
Also the design likely has been tested against everything short of being hit by an 18-wheeler, knowing George
Cheers!
Old 11th January 2010, 12:50 AM   #4
P.R. Audio's Avatar
A lot of old consoles from the 60's used a P-P El 84 or 6v6 amp.
Simple amp with directcoupled PP-follower revintage Solid State 16 22nd December 2009 11:10 AM
Simple 2 stage PP fet amplifier vuki Solid State 18 6th April 2006 08:39 AM
anyone tried the diy paradise simple el84 pp RockysDad Tubes / Valves 6 11th April 2005 04:19 AM
I want to make a simple UL PP amp arnoldc Tubes / Valves 19 6th March 2004 01:32 AM
Simple IT PP James D. Tubes / Valves 12 18th March 2003 07:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
