Checkout for Simple Se - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd January 2010, 06:53 PM   #1
royd55 is offline royd55  United States
Default Checkout for Simple Se
I am going to order my pwt and opt's from Edcor tommorrow.
I was reading ahead to see what the checkout procedure would be for the simple se and couldn't find a specific process on the tubelab site. I did see mention of a cd that was included with the board. I don't think i got one with my board, but if i did, i can't find it.
I read the safety pages on the website and have purchased 4 voltmeters and have the minigrabber connections on them.
Thanks in advance.
Roy
Old 3rd January 2010, 07:09 PM   #2
The Cd is on his web site. The procedure I used was to:
With No Tubes:
1) Double Check all connections
2) Check filament voltages
With Rectifier Only
1) Verify B+ (briefly and depends on PT voltage. Don't want to exceed cap ratings)
With 8ohm resitor across output and all tubes
1) Check for no AC at output.
2) Check B+
3) After a few minutes make sure tubes are not showing hotspots
With Cheap speaker listen to it.
It is autobiasing so you should not have to adjust any setpoints. Have fun and be safe.
Living Life Doing the Waltz in 4/4 meter.
Last edited by SGregory; 3rd January 2010 at 07:10 PM. Reason: Fixed some stupid typo's
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
Final checkout problems with Tubelab SE Mazuki Tubelab 11 21st June 2009 12:50 AM
Checkout - A really nice software for Macintosh only peranders The Lounge 3 30th May 2008 02:03 PM
Checkout the Nelson Pass inspired GC hifimaker Chip Amps 0 25th January 2005 11:12 PM
signal tracing or other circuit checkout methods Zapped Pass Labs 7 12th September 2002 06:53 PM
Copyright 1999-2017 diyAudio
