Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 28th May 2010, 12:24 PM   #11
Skorpio is offline Skorpio  Denmark
I have tried with different driver tubes (no other things changed) and got the following values:
12AT7:
Ugk: 2.1V
Ia: 10mA
Ua:250V
Vout:20Vrms
12AU7:
Ugk: 2.2V
Ia: 10mA
Ua:140V
Vout:6Vrms
12BH7A:
Ugk: 2.2V
Ia: 10mA
Ua:110V
Vout:6Vrms
Would it be a good idea to change kathode resistor to even up the Ua? Or would it be better to change current source to ie. 20mA? It might get too hot?
Alternative is to change CCS to a 22K power resistor...
Old 28th May 2010, 05:15 PM   #12
Davec113 is offline Davec113  United States
Davec113's Avatar
12AT7:
Ugk: 2.1V
Ia: 10mA
Ua:250V
Vout:20Vrms
12AU7:
Ugk: 2.2V
Ia: 10mA
Ua:140V
Vout:6Vrms
12BH7A:
Ugk: 2.2V
Ia: 10mA
Ua:110V
Vout:6Vrms
I'm using a 12BH7 and started with a jj ecc99. Both run 20 mA Ia, and I changed the resistor on the current source to do so. The resistor values and corresponding amperages are on the ccs datasheet, I think it was linear so I use a 150r resistor, but it's been a couple years or so now so best to double check. They have done fine so far putting out that much current, no heat issues so far.
I like the way the bh7 sounds, but I think you need to give it more current to really evaluate it correctly.
Simple SE driver tubesHide this!Advertise here!
Simple SE and 6BG6GA's whitelabrat Tubelab 18 25th October 2011 05:46 PM
Simple Simple SE questions nodiak Tubelab 57 3rd February 2010 12:02 AM
simple SE questions skipper Tubelab 9 10th January 2010 07:05 PM
simple se troubleshooting nukaidee Tubelab 2 13th July 2009 03:04 PM
sweept tubes for simple Se recommendation? dubdub Tubelab 6 31st March 2009 02:25 AM
