Throw it on the heap... SSE - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 30th December 2009, 06:52 PM   #1
JdJ is offline JdJ
Thumbs up Throw it on the heap... SSE
Well with very little headache another SSE was born... I learned a few things along the way:
-One of the big ones was it's hard to cram one of these puppies in a 12.5x8x3 chassis. But I did it!
-Don't measure the resistance of the cathode resistors in circuit when warm - they will skew your readings leading you to think that your dissipation is MUCH lower than it actually is.
-I never figured out what was up with my SS rectifiers, but they were causing problems so they are gone... I used 512-ISL9R8120P2
8A 1200V STEALTH from Mouser - maybe the package is different from the FREDs - I never checked (read: DUMB!)
I thought I remembered someone saying the JJs EL34-L can handle higher dissipation than the standard EL34. The JJ chart says 25w max, but the tube database on Duncan Amps says 35?! I am running just under 26 with no plate glow.
Anyway - it sounds amazing!!
Old 30th December 2009, 07:34 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Looks great
Jim
The machine does not isolate us from the great problems of nature but plunges us more deeply into them. - Antoine de Saint-Exupéry
Old 30th December 2009, 07:39 PM   #3
Brit01 is offline Brit01  United Kingdom
Is that a big power supply oil cap squeezed in there?
Old 30th December 2009, 07:42 PM   #4
JdJ is offline JdJ
Thanks!
Indeed - a 80uF 370VAC. I had to shoe-horn it in there as there was no real estate left on the top panel...
Old 30th December 2009, 07:47 PM   #5
Davec113's Avatar
Nice amp. I've been running winged C el34s at 29 W dissipation in triode for a long time w/o problem.
Old 30th December 2009, 07:52 PM   #6
astouffer's Avatar
That shouldn't happen to a resistor. You were probably reading a bypass capacitor in parallel.
Old 30th December 2009, 08:16 PM   #7
JdJ is offline JdJ
Good to know - I went back to the TDSL and I must have mis-read it. All of the EL34 variations I looked at seem to have a max of 25 watts...
That's what I was thinking too. I haven't checked the schematic yet to see. I had read one of the myriad SSE posts where someone said they fluctuate with heat, but I can't find the post to re-read it so who knows, maybe I made it up... The long and short is I pulled one out while it was still warm and it was within 1% of where it was before.
-J
Old 30th December 2009, 09:11 PM   #8
Ty_Bower's Avatar
Nice work. I felt like I was struggling to get it all in 9"x14". Still, I'm going to have to give you partial credit - the OPT are hanging off the edge!
Old 30th December 2009, 11:29 PM   #9
JdJ is offline JdJ
Ha! True - hence the "bash guard" to help balance it aesthetically.
Tubelab SSE inrush current limiters. syyma Tubelab 9 28th August 2009 09:31 PM
Tubelab SSE measurements budmaestro Tubelab 8 25th June 2009 12:41 AM
Tubelab sse transformer wires newtube Tubelab 9 12th May 2009 02:29 PM
Fisher CA-272 pulled from trash heap... rev_psilocybe Solid State 1 10th July 2005 01:55 PM
Copyright ©1999-2017 diyAudio
