| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
I am building a simple SE using KT88 tubes with a choke supply - a few questions follow:
1. What value should I use for the R17 and R27 resistors? 2. I am going to use a socket with a filter and fuse - what AC line power rating should I specify? 3. There are several switches used for the amp - the standby, ultralinear and cathode feedback switch. Any recommendations on which switches to select? Thanks all Salsero |
#2 | |
From Simple SE : "The assembly instructions for the Simple SE show the optional installation of a standby switch. There have been a few instances of blown diodes associated with the use of a standby switch. Investigation has revealed that some power transformers (particularly Hammonds) can generate a 2500 volt spike when the standby switch is operated. It is recommended that the standby switch be omitted from new builds, and not used on existing amps. The instructions will be changed as soon as I can get to it." |
#3 |
Tubie Noobie
Salsero,
What is the power transformer you will be using and the DCR of the choke and the impedane of your OPT's. To determine the value of the resistors optimally you need to estimate your plate voltage. Using the table in the assembly manual we can then determine the resistor value based on how hard you want to drive your tubes. For Example, in mine I use the EDCOR XPWR033 which will get me close to 450VB+ with 150OHM DCR on my choke. I used 560Ohms for R17/27. The only switches I use is the Power and sometimes the CFB. I run CFB almost all the time. I do have the UltraLinear switch installed but don't care for the sound (personal preference). I am also driving 4ohm speakers with little transformers. UL sounds whizzy to me. I am using a 1.5amp sloblo fuse. No thermistor.
Living Life Doing the Waltz in 4/4 meter. |
#4 |
George,
The boards arrived, thank you very much ! I have a couple of questions: 1) For the simpleSe, my transformer does not have a 6.3V 5A secondary, but two 6.3V 3A. Can I connect them in parallel in the board socket ? 2) I saw in the schematic of the PSU of the SimpleSE that you do something that I would like to understand, connecting the B+ to the heater. What's the theory behind that ? 3) Did I understand correctly that the SimpleSE uses hybrid rectification ? What are the advantages and disadvantages of this approach ? Thanks, Davide |
#5 |
I have not found the heat sinks for the CCS. I tried Mouser and Digikey. Maybe I am just missing it. Anyone, please let me know what current part number and source to look for? Furthermore, after reading the heat sink requirements for the CCS, should I try to get a bigger heat sink than the one described in the Tubelab parts section?
Thanks Salsero |
#6 |
I used the 532-530714B00 heatsink from Mouser. You might also want to include its mounting kit, 532-4880SG.
I'd encourage the use of a slightly larger heatsink if you can be sure you will have enough space to mount it. These little heatsinks will work fine with a 12AT7, but I have some other substitutes that like to draw a lot of current. This makes the CCS need to dump a lot of voltage to keep the current at spec and the heatsinks can run hot. |
#7 |
Do the heatsink and transistor actually need to be screwed to the PCB? If you build the inverted configuration why not use a larger heatsink and install them on an angle say at 45 degrees?
#8 |
As long as the heat sink is attached to the chassis somehow, you can do whatever you want. You don't want to depend on the IC leads to be the only mechanical support for a heavy heat sink.
#9 |
I've read through the Simple SE instructions but I'm not clear on how we determine B+ voltage.
This is my 1st build so I'm going with the default configuration. But the parts list states that you might need to make changes to R17/27 and C1/C2 depending on your build. Where did I miss the instructions for calculating these new values? The current plan is to use the Edcore XPWR059 power transformer 750V (375-0-375) and the following tubes: JJ6L6GC outputs, JJGZ34/5AR4 rectifier and JJ ECC81 as my 12AT7 equivalent. I thought the B+ for this combination is 450 so going to the 'tubes and transformers' page do I get 6L6GC 450 5000 437 37 560 66 27 3.95 .... 3.95 Watts for my power output? Per the table instructions, I'm not sure how to get a B+ value based upon my transformer. Lastly, can someone recommend a DPDT rotary switch suitable for use for the Triode/UL control and CFB selector? I also plan to include the choke and the power supply cap. those additions don't appear to impact any on board components, right? thanks! |
#10 | ||||
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
| Tubelab Simple SE questions | Skorpio | Tubes / Valves | 18 | 3rd May 2010 02:43 PM |
| Simple Simple SE questions | nodiak | Tubelab | 57 | 2nd February 2010 11:02 PM |
| My Simple SE via Akihabara | bigjppop | Tubes / Valves | 45 | 2nd February 2010 09:07 AM |
| simple SE questions | skipper | Tubes / Valves | 9 | 10th January 2010 06:05 PM |
| Simple SE Cap and layout questions??? | BillEpstein | Tubes / Valves | 1 | 23rd April 2009 02:47 PM |
| Page generated in 0.12273 seconds (82.92% PHP - 17.08% MySQL) with 10 queries |
