Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd February 2012, 12:21 AM   #11
All right... time to order some parts! thanks George!
Old 2nd February 2012, 02:46 PM   #12
One more question... so if you plan to add the choke, but want to test the basic amp first without the chock to make sure everything is working, do you install the 150 ohm 5 Watt resistor and then cut it out or can you just leave it out?
Old 2nd February 2012, 03:00 PM   #13
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
If you plan to power the amp without a choke, a resistor must be in its spot on the board or across the choke connectors.
Tubelab Simple SE questions Skorpio Tubes / Valves 18 3rd May 2010 02:43 PM
Simple Simple SE questions nodiak Tubelab 57 2nd February 2010 11:02 PM
My Simple SE via Akihabara bigjppop Tubes / Valves 45 2nd February 2010 09:07 AM
simple SE questions skipper Tubes / Valves 9 10th January 2010 06:05 PM
Simple SE Cap and layout questions??? BillEpstein Tubes / Valves 1 23rd April 2009 02:47 PM
Page generated in 0.07497 seconds (74.07% PHP - 25.93% MySQL) with 10 queries
