Pictures of your Tubelab amp - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 31st December 2009, 10:36 PM   #31
Davec113's Avatar
Old 31st December 2009, 11:05 PM   #32
I've actually been lusting after your amp for quite some time and I was hoping you'd post some more pictures. I love the wood. I thought I remembered you posting what type of wood it was in another thread but I've forgotten. How did you finish yours?
My chassis is in clamps now but has Makore rails and figured maple posts.
Old 1st January 2010, 01:34 AM   #33
Davec113
Absolutely Fantastic! I too am interested in what kind of wood.
Living Life Doing the Waltz in 4/4 meter.
Old 1st January 2010, 05:19 PM   #34
Davec113's Avatar
Thanks!
The chassis is Maple with some splating and burl, and I used figured Walnut for the corners. Ebay has a great selection of craft wood, I got mine from antlersexpress. I recently picked up some amazingly nice walnut from him to make a rack out of. I also managed to get enough Maple and closeout Harbor Freight plumb bobs to make speaker stands too.
Old 4th January 2010, 01:07 AM   #35
Default Tubelab SE 300b
Here is a recently completed Tubelab SE. Chinese Mesh Plate 300b. The plates really are not glowing red, my camera plus software enhances just makes it look that way. They do have a pretty blue on the glass from electron emmision. Compared to my kt88SSE, this amp is much more detailed and has better sound stage. Bass is also much tighter and deeper. Bit of apples to orange comparison though since the outputs are the bigger edcor csxe's.
Old 4th January 2010, 01:44 AM   #36
Tubelab_com's Avatar
I guess I need to add a few pictures of mine, even though they aren't finished yet.
The first one is a working 6CW5 amp. The 6CW5 version uses a solid state rectifier. The volume control, power switch, speaker and input jacks, and IEC connector aren't mounted yet. In fact the amp is still connected up with clip leads, but I haven't been here. I might get it finished next weekend if it doesn't rain.
The second picture is a different board wired up as a PPP mono block. It is running on an external power supply in this picture so I could determine just how much power I could get out of it before it exploded, and what voltage would be needed to do so. Then I could back up a little. The picture was taken at the point where I decided that I was rather fond of this amp in working condition, so I stopped at 420 volts! I was using 4 well used 1962 vintage 6BQ5's and I was getting 60 watts out of them. The mono block conversion was accomplished in this case by removing one 12AT7 and attaching a few clip leads. I am already planning to repeat the experiment and completly document the modifications. A complete amplifier is planned.
The third picture is the same as the second but the room lights are turned on.
More pictures after these guys (and their siblings) are finished. There really will be pictures of amps with the rectifier tube in them.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 4th January 2010, 12:15 PM   #37
Oh boy, now I'm probably going to have to buy two! What kind of power would you expect at some more sane voltage?
Old 4th January 2010, 11:10 PM   #38
urmoo is offline urmoo  Estonia
urmoo's Avatar
Simple SE, KT66, Edcor transformers. Front panel and volume knob has been fixed and replaced since photo was taken.
Specially for this amp I built a set of horn type of speakers (Visaton BG20 elements were used)
Result? My good ol Sony have got no speaker-time since my Elise (as Beethoven's "Für Elise") got ready.
Old 5th January 2010, 02:37 AM   #39
I will know more after I get back to this. Some "EL84's" seem to self destruct at much over 15 watts per pair which would give 30 WPC in dual mono blocks, but these and the current production JJ's seem happy at 25 to 30 watts per pair. I will shoot for the most power available without over stressing good tubes (JJ or the old Sylvanias). I will aim for 40 to 50 WPC, but a lot depends on finding a suitable power transformer.
See post 15 in this thread:
When will Simple P-P be ready?
Old 5th January 2010, 08:43 PM   #40
Davec113's Avatar
Wow, now thats some nice woodworking (as opposed to my amp, which just has some nice wood)
Is that a preamp in the background of the 1st pic?
Tubelab SE amp question smbrown Tubelab 8 21st September 2009 06:05 PM
Tubelab SE 45... Super amp!? colivet Tubelab 0 26th August 2008 12:38 PM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
Switchable stages with Tubelab’s hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 08:56 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 04:39 PM
Copyright ©1999-2017 diyAudio
