Pictures of your Tubelab amp - Page 25 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th April 2013, 01:22 AM   #241
Default Ground
I didn't like the way I had the wire routed, I had to re-do it. There is a inline fuse hidden underneath the aux cap right befor the switch. I was actually waiting for someone to ask about the ground.
Old 8th August 2013, 05:51 PM   #242
schebb is offline schebb  Canada
A few photos of my SSE. I love building and listening to these tube amplifiers. The large hole milled into the bottom of the chassis is for the future install of a motor run cap.
If the images were uploaded too large, please let me know.
Old 9th August 2013, 06:48 AM   #243
Mooly's Avatar
Hows that ?
Go to the gallery and click your picture and then highlight and copy and paste the link into the thread
Old 9th August 2013, 10:47 AM   #244
kkcinc is offline kkcinc  United States
I love it, but that's a lot of voltage to be doing 'breadboard' style!
Old 9th August 2013, 02:18 PM   #245
Kkcinc,
To be fair, what voltage is low enough to do antique style? Any voltage high enough to cause current to flow through the body's tissues is dangerous, including our source of 120 VAC. If you contact it you may get hurt or worse. If you do not contact it, no worries.
Having said that, you are 110% correct.
Right now the amp runs in an enclosed room behind my audio rack which has a lockable door. I am trying to source some of that old antique expanded metal that you see at times covering tube equipment or old oil burning stoves. I will have a box built that will fit around the board and wires and fasten it to the chassis. Retro look, safe, adequate cooling, and still see the glow. Nirvana! Thanks.
Steve
Old 9th August 2013, 03:05 PM   #246
Sorry, In the above post, #245, meant to start with 'what voltage is low enough to do "breadboard" style'. Thanks
Steve
Old 3rd October 2013, 10:49 PM   #247
Default Tubelab SSE
My Tubelab SSE
Old 3rd October 2013, 11:36 PM   #248
Very nice, great work !
Old 4th October 2013, 02:25 AM   #249
Sodacose's Avatar
Not the greatest photo, but it was baptized about 30min ago! Fantastic little amp.
Old 22nd November 2013, 02:23 AM   #250
dmb5245 is offline dmb5245  United States
My SSE:
Edcor GXSE OPTs and XPWR035 PT, JJ EL34 tubes with 680ohm cathode resistor, UL/Triode switch and CFB switch, tube rectification. The only unique modification to the SSE design is the addition of an RCA selector switch so it can run double duty for home theater without swapping wires. At some point I'd like to buy some different tubes and add a selector switch for variable cathode resistance like so many people here have done, but that can wait. The chassis design is shamelessly stolen from others on this thread and constructed of red oak, cherry, and 1/8" aluminum. Thanks to Tubelab for a great circuit design and PCB and thanks to the DIYAudio community for all the useful information on this forum.
Tubelab SE amp question smbrown Tubelab 8 21st September 2009 05:05 PM
Tubelab SE 45... Super amp!? colivet Tubelab 0 26th August 2008 11:38 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
Switchable stages with Tubelabís hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 07:56 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 03:39 PM
Copyright ©1999-2017 diyAudio
