Pictures of your Tubelab amp - Page 15 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 17th April 2011, 06:21 PM   #141
yoaudio is offline yoaudio  United States
yoaudio's Avatar
Default Tubelab SE with 866A mercury vapor rectifiers.
Found this on on the diytube forum board-- too cool!!!!!!!!
Old 17th April 2011, 06:23 PM   #142
weskoki is offline weskoki  Europe
weskoki's Avatar
Let me take my glasses
Old 18th April 2011, 12:45 AM   #143
wa4swj is offline wa4swj  United States
Hi Guys,
That's my amp. That picture was taken before I built the base. Here's a link to the finished result:
It is a hybrid design - a hand built tubelab SE (no circuit board) and a mercury vapor tube power supply. The OPTs are ElectraPrint. Jack made them for me and they are marvelous. This amp is by far the best one I've built. It's amazing. All the credit goes to George's Power Drive idea. I have it driving a pair of Zaph Audio ZRT's that I built. Wonderful speakers as well. I also have a tubelab SE with George's circuit board that I use in my office. It is a very good sounding amp too.
(Unfortunately I've never been successful linking pictures.)
Best regards,
Ed Long
Old 18th April 2011, 03:14 PM   #144
How much hybrid is it? I see twice as many parts in power supply side so I'm wondering...
Old 18th April 2011, 03:48 PM   #145
Guys,
It's a tubelab SE amplifier with a mercury vapor rectifier power supply instead of the usual power supply as designed in to George's board. I did that just for fun and for something different. From a cost standpoint (it costs a lot more) and probably a performance standpoint it probably doesn't make sense because the power supply probably doesn't have that much effect. But because it looks cool and uses mercury vapor tubes (because I just wanted to use some) I like it and it was a good challenge to do the panel design and build. It certainly sounds better than all my other amps and I have quite a few. Most of the quality of this one is due to George's amplifier design and the OPT's. The amplifier portion is pretty much exactly the same as a tubelab SE. The 417A/300B filaments are DC but use different regulators (2). The power supply is pretty much standard fare for MV tubes. Something similar can be found in Pete Millet's Unnecessarily Complex Amplifier. That was a portion of the inspiration for this amp too.
So it's a mix of a tubelab SE with a much different power supply.
Ed Long
Old 21st April 2011, 12:23 PM   #146
wagtail is offline wagtail  Ireland
wagtail's Avatar
hi guys,
finished my spp build, sounds great with FH3's.
gonna need help with measurement will post on other thread.
thanks george did what i set out to do ,build a tube amp and learn some on the way.
simon
Old 21st April 2011, 02:48 PM   #147
boywonder's Avatar
Interesting chassis......Did it start out life as a hot plate or something?
Old 21st April 2011, 03:49 PM   #148
wagtail's Avatar
no, it's bent up from a length of aluminium flat bar with al. angle supporting trannies.
Old 21st April 2011, 04:41 PM   #149
wagtail's Avatar
found an earlier pic. i just used mat'l i had in the workshop,
Old 24th April 2011, 10:03 AM   #150
Moko is offline Moko  United Kingdom
Where did you get those transformers they look great? How do they sound?
Tubelab SE amp question smbrown Tubelab 8 21st September 2009 05:05 PM
Tubelab SE 45... Super amp!? colivet Tubelab 0 26th August 2008 11:38 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
Switchable stages with Tubelabís hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 07:56 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 03:39 PM
Copyright ©1999-2017 diyAudio
