| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#101 | |
#102 |
#103 |
I built a set of Saburos with Planet10 EnABLed Fostex FE126eN drivers.
#104 |
#105 |
Very Nice Build!!! Craftsmanship looks professional.
#106 |
So,
I just completed a TubelabSE to be used with 45 and 2A3. It's more "conservative" compare to the "Cinderella Castle" for the 300B, and everything went incredibly smoothly in the construction. Particularities are that the two 10 ohm resistor to measure the bias are mounted off board under the measuring point, and I made holes, do that the bias can be adjusted without opening the chassis. I found the chassis in Akihabara, the Tokyo electronic district. The iron comes from Thailand, from Silk. The owner was very kind and he custom made the power transformer for me. I am still thinking about a version of the Tubelab SE with regulated PSU, but it will take a while. Davide P.S.: This time pictures were taken with a Nikon |
#107 |
My 2nd Amplifier with Tubelab SE pcb and 300b
#108 |
#109 |
no.They are vertical oriented.
#110 |
The PT with choke are vertical oriented with OT.
| Tubelab SE amp question | smbrown | Tubes / Valves | 8 | 21st September 2009 06:05 PM |
| Tubelab SE 45... Super amp!? | colivet | Tubes / Valves | 0 | 26th August 2008 12:38 PM |
| Tubelab Simple SE & Edcor | waam68 | Tubes / Valves | 2 | 6th March 2008 01:15 PM |
| Switchable stages with Tubelab’s hybrid MOSFET/ 845 SE amp? | rick57 | Tubes / Valves | 0 | 5th September 2006 08:56 AM |
| Especially for Tubelab: 845 amp 2.0 | Giaime | Tubes / Valves | 24 | 30th July 2006 04:39 PM |
| Page generated in 0.12060 seconds (70.15% PHP - 29.85% MySQL) with 11 queries |
