Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd January 2011, 04:32 PM   #121
Structo is offline Structo  United States
Structo's Avatar
That is cool with the lexan cover.
Tom
Keep that smoke in the amp!
Old 15th January 2011, 01:37 PM   #122
debk is offline debk  United States
debk's Avatar
My Tubelab SE!
Amp sounds great. Very happy with the project
Debra
Old 15th January 2011, 05:51 PM   #123
Evenharmonics is offline Evenharmonics  United States
What did you use to cut those vent slots?
Old 15th January 2011, 06:36 PM   #124
debk's Avatar
I had the top panel fabricated by Frontpanel Express
Deb
Old 16th January 2011, 04:09 PM   #125
bigjppop is offline bigjppop  United States
Nice! I love the top panel divided in two to allow easy access underneath. Great idea.
I'm also pretty convinced that Front Panel Express will be doing all of my further chassis panels... I'm done with that part of the DIY world.
Old 20th February 2011, 06:11 PM   #126
boywonder is offline boywonder  United States
boywonder's Avatar
Default My Tubelab SE
Finally finished my amp......
Old 20th February 2011, 07:52 PM   #127
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Looking good!
Sent from my Xoom using Tapatalk
Old 20th February 2011, 07:56 PM   #128
Structo's Avatar
Can you tell me more about what you did with it?
Obviously separate power supply, is that to reduce hum?
Chassis? Did you build that from scratch or buy it somewhere?
What are you driving it with?
Tom
Old 20th February 2011, 09:15 PM   #129
boywonder's Avatar
Yes, separate power transformer to reduce hum. I would have done more PS components on the PS chassis, but the PCB makes things convenient to leave them in the main chassis. I had umbilical connectors & cable laying around so what the heck.
I built both chassis from scratch using a mill and a table saw....and planer, pop-riveter, lacquer sprayer, bead-blaster, etc etc......only took about 430 man-hours .
I have a couple of preamps including an Aikido; lately I've been using an Anthem Pre-1.
A few details:
Power transformer is an Edcor XPR-131 with it's endbells stripped and painted with hammer tone Rustoleum.
I took the pics with a GZ37 rectifier in place; I'm presently using a 5AR4, but I'm going to pop in the GZ37 once I'm comfortable everything's in it's happy place.
James 6123 transformers on the 5K tap, James 5H choke, JJ 300B's
100uf ASC motor run bead-blasted, in parallel with a 180uf/500V Panasonic TS-UP mounted on the board. I also made a separate board to hold snap-in style bias supply caps since they were a little tall for the chassis. They are mounted to the sidewall under the hood. C1 is a 4.7uf.
It's presently set up with 360V/70ma on the 300B's. I plan on playing around with the 3.5K transformer taps etc.
Old 20th February 2011, 11:57 PM   #130
Structo's Avatar
Man that looks totally pro.
The James transformers look so cool!
I'll bet it sounds great!
Tom
Pictures of your Tubelab ampHide this!Advertise here!
Tubelab SE amp question smbrown Tubelab 8 21st September 2009 06:05 PM
Tubelab SE 45... Super amp!? colivet Tubelab 0 26th August 2008 12:38 PM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
Switchable stages with Tubelabís hybrid MOSFET/ 845 SE amp? rick57 Tubelab 0 5th September 2006 08:56 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 04:39 PM
Copyright ©1999-2017 diyAudio
