Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 19th December 2010, 04:30 PM   #11
w5jag is offline w5jag  United States
Eric,
If you look at the T3 Sec and T2 Sec terminals, you will see that they are configured as follows: one of the two terminals connects to the negative lead of the cathode bypass capacitor, and the other is connected to the ground plane of the printed circuit board, thus when these two terminals are jumpered, the negative lead of the cathode bypass capacitor is grounded.
I use an unconventional method of cathode bypass with my Hammond 125ESE as detailed above: remove the jumper, and connect an unused secondary lead to the T2/T3 Sec terminal that connects to the negative lead of the same side cathode bypass capacitor. Nothing more needs to be done. I'm sorry I can't be more explicit and give you the exact pin number - I'm at our secondary residence and have no simple se board handy. Perhaps someone else does.
BTW, your pictures above show considerable plate glow on one of your EL34's. If you can see this glow with the unaided eye, that tube is bad. Discard it and replace it with a good one.
Win W5JAG
tubelab simple SE Tube selection helpHide this!Advertise here!
Tubelab Simple P-P booangler Tubelab 711 28th May 2018 03:39 AM
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 04:15 AM
