Tubelab Simple P-P - Page 48 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 16th November 2011, 01:58 PM   #471
BuzS is offline BuzS  United States
Money sent. Thanks.
Old 16th November 2011, 05:39 PM   #472
chrisb is online now chrisb  Canada
Originally Posted by rknize View Post
I'm doing exactly that to R6 in the TSE. R1 definitely needs to be uprated to a 7W part at least. My SPP will be getting a choke in place of R1, if I ever get around to it.
actually I did the same myself - IIRC it required breaking a foil trace on the board to
I mentioned the issue with R1 to George over email some time ago (last year?), but I know he has a hard time keeping up with all the emails. Mine is pretty toasted looking now (I use the SPP in my shop), but it's still alive.
After identifying an early problem with defective rectifier tube that kept blowing mains fuses, the warmest running part on mine is the power transformer. I've been thinking about converting to SS diodes to relieve some of the thermal load on filament taps - that'd be a lot easier than upsizing the PTX. With existing choke and possible addition of film caps in the power supply, and maybe adjusting series R to keep B+ in line, I doubt I'd hear enough difference in the particular system.
on hiatus
Old 17th November 2011, 10:38 AM   #473
pso is offline pso  Spain
No C103 , C203 , C105 , C205 in this board.
Old 17th November 2011, 10:53 AM   #474
Sorry , I just realized that if they are.
Old 19th November 2011, 01:57 PM   #475
Hi.
This LED to VISHAY TLDR5400 work in the cathode of a SPP ? , if it did not , one can specifi a part ?
Thanks.
Old 19th November 2011, 11:25 PM   #476
Ian444 is offline Ian444  Australia
LED's in the cathodes of the EL84's?
You could try these Fairchild MV50152.
http://i198.photobucket.com/albums/a...LEDarrays1.jpg
http://i198.photobucket.com/albums/a...LEDarrays3.jpg
You can get them from here.
Biasing can be tricky, and depends a lot on the B+ of the amp, the output tubes and the matching of the LED's.
Old 20th November 2011, 11:14 PM   #477
Thanks Ian444 , but unfortunately are no longer available at Mouser or Digikey.
Old 20th November 2011, 11:48 PM   #478
Thanks for the link , if I want to try and where to look , long were installed ? rather endure the abuse ?
Old 21st November 2011, 12:31 AM   #479
The choke and motor run cap provide some benefit , even a littel , or are completely unnecessary ?
Old 21st November 2011, 09:09 PM   #480
In this and several other projects (SE and P/P) appropriately spec'ed chokes and film caps in power supply were worth every penny. I've never heard anyone complain of sonics of motor run caps, but they certainly can impose some dimensional if not budgetary issues.
on hiatus
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 06:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 04:15 AM
Copyright 1999-2017 diyAudio
