Tubelab Simple P-P - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 7th October 2009, 11:54 PM   #121
Ty_Bower's Avatar
Sylvanias are good.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
http://i69.photobucket.com/albums/i4...Tubes/syl1.jpg
http://i69.photobucket.com/albums/i4...Tubes/syl2.jpg
http://i69.photobucket.com/albums/i4...Tubes/syl3.jpg
Old 8th October 2009, 02:59 AM   #122
Tubelab_com's Avatar
-GE 5-star 6201's (triple mica gray plates)
I looked over at the Simple P-P that is currently playing and the two 6201's are indeed GE 5 star tubes. I looked into the box that is full of loose 6201 tubes and they are mostly Sylvania but about 1/3 of them are GE 6201WA. Some of the Sylvania's are 6201GB (Gold Bond). I guess this must be their answer to the GE 5 star. All seem to work good.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 8th October 2009, 07:52 AM   #123
MellowTone's Avatar
Originally Posted by SigloOne View Post
If I recall correctly, the Simple P-P will require 12AT7's in the front end. Any suggestions for brands to look for?
I've been using 12AU7 tubes in my Simple SE (it's been working fine, any input George?) and my favourite by far is the used (old stock) Tung Sol that I picked up cheap. I have a few (also used) Cifte tubes that sound good as well. Fo some reason, the two Electro Harmonix 12AU7's I have sound pretty ordinary, if not just plain bad. I've got some NOS Tung Sol, RCA and GE 12AT7's on the way, and just as many NOS 12AU7's and 12AV7's.
I Reject Your Reality And Substitute My Own
- Adam Savage, Mythbuster
Old 8th October 2009, 01:38 PM   #124
Ty_Bower's Avatar
I'm not George, but I'll add my two cents anyway. If you like the sound, then I'd say go for it. The 12AU7 should be just fine. Keep an eye on the heatsinks attached to the IXCP10M45S (the CCS). I'd expect they will be getting hotter with a 12AU7 than they would with the 12AT7 as the watts dissipated in the CCS will be higher (roughly 2.5 watts, vs. 1.5 watts).
Don't try touching them with your finger to check the temperature. They've got 400 volts on them!
Old 8th October 2009, 02:17 PM   #125
MellowTone's Avatar
Hey Ty, thanks for the input. I think the CSS modules should be fine, I've got a sink on them that's quite a bit larger that the ones spec'd by George (extruded aluminium, around 12x18x10mm) Don't worry, I definitely won't be touching them. And yes, the 12AU7's in my amp sound great to me.
By the way, after seeing some of the amps you've made and reading some of your posts around diyAudio started my love for the 6P3S-e tube. They're brilliant valves, sound fantastic. The only problem is that now the build of most tubes just doesn't seem good enough
Old 14th October 2009, 11:28 PM   #126
Just wondering how progress is going on the Simple P-P.
Thanks!
Old 15th October 2009, 12:51 AM   #127
I'm so excited I can barely sit still. George I should send you a few dollars to pay for the traffic I'm clocking up checking your site every few hours ;P
Old 15th October 2009, 01:35 AM   #128
Right behind ja. I check everyday.
I need something to warm up my basement this winter.
Scott
Old 15th October 2009, 05:28 AM   #129
noodle is offline noodle  United States
Based on the successful sales of a new simple preamp from bottlehead, i suspect there is a fair amount of pent up demand and this amp should do well. Especially if it gets out before bottleheads stereomour.
Old 15th October 2009, 11:55 PM   #130
We got "the" phone call, and set out on our trip on Tuesday. I loaded up the laptop with all of the stuff needed to work on the manual. I planned to work on it while Sherri drove but the weather was so lousy that I did most of the driving. We got to Sherris mothers house in West Virginia late last night. It is currently 40 degrees and raining, but that is a welcome change from the record breaking heat that we left behind in Florida (92 to 94 degrees every day).
I had to fix the phone line (outside in the rain) this morning to get the internet to work (too much hum) so I could check in here. I'll be here for a week or so before heading back south. The exact scherule will be determined by the cancer speciallists in Pittsburgh on Monday. My laptop will follow me and I will be working on the manual whenever I get a chance.
My current web hosting plan gives me plenty of bandwidth. I will post the progress right here as anything changes. I realize that I haven't updated my web site in a long time and I have all sorts of new stuff to post, but the Simple P-P is priority one right now. I have some new pictures of the Simple P-P boards to post, but I didn't get the time to post them before I had to leave on this trip.
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 01:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 01:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 07:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 05:15 AM
Copyright 1999-2017 diyAudio
