Tubelab Simple P-P Tubelab Simple P-P - Page 55 - diyAudio
Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 31st January 2012, 10:48 PM   #541
zman01 is offline zman01  Bangladesh
Tubelab Simple P-P
Originally Posted by nightanole View Post
How do these look?
Dale 23 Step Attenuator 2-Chl Volume potentiometer 50k | eBay pt=LH_DefaultDomain_0&hash=item4aae0012c6
http://www.ebay.com/itm/DALE-4X24-St...item336af0fff5
Old 1st February 2012, 01:27 AM   #542
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
Perhaps George will find a way to correct this in the future. And perhaps he did try it, but couldn't get the PCP to allow for it.
I don't claim to be artistic, but I do like things that are symmetrical. I am foremost an engineer and I design things for function first, then fit the form around them.
Of course the rectifier tube is always the odball since it is usually a different size than the other tubes. This is the case in most amplifiers. The logical place to put the rectifier is on the centerline of the PC board to preserve symmentry. From an engineering standpoint this is about the worse place to put it.
The rectifier and surrounding circuitry handles hundreds of volts of 50 or 60 Hz. It also passes high currents in short bursts. The rectifier must be kept as far as possible from the input circuitry to avoid hum. The traces to and from the rectifier must be carefully routed to create the PC board version of a single point ground (SSE and TSE) or a ground bus (SPP).
The only place to put the rectifier electrically that would satisfy the symmetry criteria would be in the center of the back edge of the PC board with two output tubes on each side. The circuitry supporting the rectifier tube must be kept in its own island of ground with only one ground connection to the rest of the PC board at the negative terminal of the output filter capacitor. Designing a PC board for a tube amplifier is actually a lot like making a point to point version. Fortunately it only has to be done right once. Every exact copy of the correct design will be the same and hum free.
Placing the rectifier in the center of the back of the board will make the board a lot wider. A wider board costs more to manufacture and triggers an oversize charge with some PC board vendors. It also makes it harder for the finished amplifier to be built with the golden ratio without making it rather large.
Up until recently the active screen size of all TV sets and most computer monitors was 4:3 which is 1.33:1, HDTV is 16:9 which is 1.77:1. It used to be common to put speakers on the sides of 4:3 monitirs to make them wider. Now the speakers are on the bottom edge to make them taller.
I am thinking of finding a way to elevate the tube sockets from the board.
I have made stilts from brass tubing with heat shrink over it.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 1st February 2012, 01:52 AM   #543
rmyauck is offline rmyauck  Canada
George I bet that board would support 7591 types as easy to drive. Just a few PS mods. Bigger trans would only cost a few $ more. Fixed bias would be needed for sure with modern production tubes from what I've read. Maybe Dave Gillespie's EFB mod would be a low cost simple way of doing it.
What do you think.?
Have you ever tried the 6973 as it's supposed to sound great?
Of course parallel EL84's could be done with other off board in the same way or use 2 boards.
Keep up the great mods!
Randy
Old 1st February 2012, 03:11 AM   #544
John L is offline John L  United States
John L's Avatar
I guess this gets us back to the need to just go with SS rectification, and eliminate the rectifier tube. The SS rectification would still be where it is on the pcb, right? We wouldn't have that single 'odd man out' tube hanging around.
Or we could mount it inside the case, horizontal with the deck, I think. Some well placed hole openings the upper deck, and an open bottom would act as decent ventilation I would think.
For my needs, I can afford to make the project wider, and with less depth. I'm not going to utilize a project case, but make the base out of wood, and the decking out of metal.
How about something like this?
It really doesn't have to be that wide, because the toroidal trans are circular and the Edcors are rectangular, taking up less width. Even transformer covers made to cut down on magnetic interference would still result in a project that is less wide. I think the symmetry of this amplifier is classically beautiful, and perhaps practical.
I really do love the pleasing shape of my HP 16:10 (1:1.6) monitor. While I'm going down the basement stairs into the shop, the screen just looks right to the eye from a distance. Even when I watch a movie on it, the small amount of unused screen at the bottom contains the controls of the program, so it utilizes the space very efficiently. But I have to admit that some monitor makers know all about that Golden Ratio, and have done the right thing by putting those speaker at the bottom of the screen.
Old 1st February 2012, 04:29 PM   #545
The SS diodes go in the PC board in the same location as the rectifier tube. They generate no heat and need no holes in the deck, so they are not visible from the top. See the picture in post #537.
This is a picture of one of my amps that used SS rectification. My main focus here was small size since I have very limited space. I put the two OPT's on the deck and used an Antek toroid for power which is hidden under the deck. The amp will still not be perfectly symmetrical since the driver tubes are offset to keep them away from the rectifier tube.
Old 1st February 2012, 04:43 PM   #546
brucetassin is offline brucetassin  United States
JohnL
You can mount all components on the UNDERSIDE of the PCB except the tube sockets. I already showed you a picture of the diodes mounted on the PC board INSTEAD of the tube socket. I found a picture on the net and KLUGED a rouff example of how your amp could look. You would need to cut holes for the tubes in the top of the box and suspend the PC board from the underside of the top plate. EDCOR only sell BLUE painted bells for their transformers but they will sell you extra UNPAINTED bell, which you could paint any color you want.
Old 3rd February 2012, 09:53 PM   #547
pieroh is offline pieroh  Germany
Default schematic Simple PP
Dear George,
where can I find a schematic of this amp on your website?
pieroh
Old 3rd February 2012, 10:23 PM   #548
syyma is offline syyma  United States
Check post#493
Old 4th February 2012, 07:29 AM   #549
many thanks! syyma
Old 28th February 2012, 04:46 AM   #550
Cold Macaroni is offline Cold Macaroni  South Korea
My valentines day present to the lady-friend arrived last week (SPP and parts kit). She got some time with the soldering iron in last weekend and managed to make it as far as the tube sockets (we couldn't resist mounting the tubes for fun... she was pleased).
With any luck, she'll make it over again in the next few days and we'll see if she can make it through the capacitors and terminal blocks (my K12-G crapped out and I have to use some crappy PC speakers until she finishes!). I expect the transformers to show up today.
Since I'm not building this one, all I can do is watch Hitchcock movies and take photos... so that's precisely what I do.
Tubelab Simple P-PHide this!Advertise here!
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 06:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 04:15 AM
Copyright ©1999-2017 diyAudio
