Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th September 2009, 04:38 AM   #91
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Ungapped toroid cores have much lower flux leakage than E-I cores, so you should not have any problems.
Old 18th September 2009, 02:17 PM   #92
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
In theory it should be OK. It might be a good idea to mock up all of the components (on a piece of plywood or your workbench) and carefully test for hum before committing to a chassis design.
The double decker Simple P-P that I started has 3 toroids all touching side to side. One of them is the power transformer. This amp is not finished yet, so I don't know the results. I have wood shop class on thursday nights, and I would have finished it last night, but lifes little roadblocks keep getting in the way.
On another ocassion I stacked the toroids on top of each other with no obvious interaction. They were all power supply transformers though.
The amp testing that I have been doing with this board has been done with a mix of toroid and conventional transformers. They have been randomly scattered on my work surface and I have yet to notice any coupling, but it is possible.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 23rd September 2009, 02:15 PM   #93
booangler is offline booangler  United States
Send a message via AIM to booangler
George,
Are you ready with the installation guide? I am still a bit new at this so I am not ready to run with scissors yet. I have been holding off on buying the boards until you have this ready to go. Can you give us an update when you have a chance.
Still sending prayers for Sheri's mom.
Alan
Old 24th September 2009, 03:11 AM   #94
Are you ready with the installation guide? ..... Can you give us an update when you have a chance.
There have been many interruptions in my work on the instructions including 50+ hour work weeks and Sherri winding up in the hospital with cardiac symptoms (all tests were clean). I have one board that I have been listening to, and three more being built for photographic purpuses. I will build amps with these boards too. Despite all of the **. I took over 700 pictures last weekend, but I am not finished yet. I will take a few hundred more pictures, then sort through them all to find the ones I like. They must then all be resized and edited for posting to the web. A trip to Sherri's moms must happen soon, but her treatments are on hold until her WBC level improves, when that happens I will be gone for about 10 days. Everything is loaded on my laptop so I can work on the instructions anywhere. Given all of these variables it is real hard to provide an exact date, but I am sitting on over $2000 worth of boards and parts (all on my credit cards), and I have sold exactly 1 board this month, so I am trying to hurry as best I can while still providing an excellent set of instructions.
Here is a photo of the 3 boards currently under construction. Note the diodes in place of the rectifier tube on one board. This is required with 6CW5 tubes. Also note the tube socket on "stilts" on another board. This lets you mount the parts on the top of the board and raise the tubes up to the deck. I used this method on a Tubelab SE with a Lexan deck for show off purposes. Astute observers will notice that in my rush, I put the tall socket on the wrong board. It should be on the board behind the one it is on. Now I get to take it off.
I got to crank the Simple P-P to eleven last night (Sherri wasn't home). It is running cheap Ebay sourced Russian 6P14P tubes, a Hammond 372HX power transformer and some surplus OPT's. The Tubelab SE likes detail and music like Norah and Diana Krall, The Simple SE is a good all around performer, but this amp likes to ROCK. It does justice to Norah and Diana, but it LIKES Pink Floyd, Ozzie, Santana, Metallica, and all sorts of vintage rock. I even enjoyed cranking some Billy Idol. Some of the punch and dynamics that I like so much in my old 300Beast are present in this amp. The only thing this amp has in common with the Beast is the surplus OPT's, could it be the OPT?
Old 24th September 2009, 12:58 PM   #95
George,
It seems like it in never stops for you and Sherri. I think that I speak for many here on diyAudio.com when I say we are thinking of the two you and wishing you the best, or praying for the two of you. I think that we all appreciate your input and insights regarding your own work, as well as the work of others.
I appreciate the update, and I looking forward to purchasing at least two, of your Simple PP boards. I have been watching the progress of this project since it first appeared on the pages of tubelab.com. i am very excited to get working on the board, and trying it out in a number of variations.
Alan
Old 24th September 2009, 01:56 PM   #96
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Oh dear,atleast the tests came back okay. Stress can cause such issues (don't ask me how I know).. You guys should take a rest (as much as possible) and don't let us add to it.
I'm very anxious to try out the universal PP driver boards once they're ready,but I can patiently wait until things settle down for you a bit.
Old 24th September 2009, 02:02 PM   #97
adwsail is offline adwsail  United States
Ditto Digitaljunkie's comments. I've got one of the boards ready for parts/stuffing but I have absolutely no problem waiting for the parts list, construction details, etc. Take a break a relax and little George. After all, this is a hobby (spelled FUN), not your job. While we may at times sound like impatient children, the ol' 'good things come to he who waits' definitely applies to your amps. Take you time and give the wife a big hug!
Old 24th September 2009, 02:35 PM   #98
I really meant for my post to come out sounding the same way. I fell short!!! While I am excited, I can wait for as long as it takes. You and Sherri need to be healthy for each other first and foremost. I think, as I said earlier, that we all care more about you than your stuff. Be well and take good care of yourself and your wife.
Alan
Old 25th September 2009, 02:30 AM   #99
SigloOne is offline SigloOne  United States
Just curious, but any idea yet on a suggested power transformer for the Simple P-P running 6CW5's?
Old 27th September 2009, 04:05 PM   #100
millerlitescott is offline millerlitescott  United States
I am curious as to the sonic differences for the different power tubes that are compatible with this board. This will be my first tube amp build and I have been looking at EL84 type amps but i am still a newb at this.
I hope to be able to purchase this board as a kit with the part to populate the board and look to everyone else for transformer suggestions.
My plan is to use this amp with some 8 ohm 90db bookshelf speakers as a secondary system with the possibility of a powered sub at a later date.
Thanks,
Scott
Tubelab Simple P-PHide this!Advertise here!
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 01:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 01:18 AM
First Project Finished-Tubelab Simple SE waam68 Tubelab 2 12th April 2008 07:23 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 01:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 05:15 AM
Copyright ©1999-2017 diyAudio
