Tubelab Simple SE - Transformer Assistance - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 5th August 2009, 03:45 PM   #11
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
The XPWR059 would be a suitable power transformer, if you wanted to go with Edcor. It has a 120/240 primary and its ratings are:
375-0-375 @ 175mA
6.3V @ 6A
5V @ 3A
It's a bit overkill on the heaters, but not by much. You could run a 5U4 rectifier if you wanted. The B+ voltage is on the high side and the current is a little less than mine. Would be good for EL34s and 6L6 types. Just make sure you spring for 500V capacitors.
The one I have on mine is the XPWR035:
370-0-370 @ 200mA
6.3 VCT @ 5A
5V @ 2A
If you really wanted the extra capacity for B+, you could just custom-order what you need. Just give them the model number as a starting point and then give the deltas.
I've been remodeling in the basement and so the SSE is seeing a lot of use. It's a great amp and I have to keep it turned way down so that the rest of the house isn't going thump-thump all night.
Russ
Old 5th August 2009, 06:19 PM   #12
JeroenR is offline JeroenR  Netherlands
Originally posted by ChrisR1983
Thanks guys - some really useful information. I searched regarding Welbourne Labs. I wont be ordering my chassis from those guys then!!
Does anyone else know of a supplier that sells wooden enclosures that will ship to the UK?
Chris
Try http://www.ae-europe.nl/aanbieding_behuizingen.htm ...
They also make transformers. I ordered my TubelabSE transformer from them...
Jeroen
Old 5th August 2009, 06:47 PM   #13
Thanks Russ.
All helpful stuff! There's a lot of reading to be done and I'll get my head around it eventually.
Edcor seem to be a popular choice on here so I'll definately go with something by them.
Still having issues with the chassis though...
Chris
Chris R
Old 5th August 2009, 08:29 PM   #14
dubdub is offline dubdub  United Kingdom
Thanks Russ.
Chris
Hi Chris
for the chassis for my simple SE project I used Pesante 300m from HiFi 2000, better quality than Hammond alu/or steel and has a very nice face plate too.
http://www.modu.it/pesante.html
But if it is a wooden chassis your after then try VT4C located in Hong Kong? While I never bought from him because I considered his postage costs to be too high for my needs- it may be worth it if you buy other items too like transformers (or even a choke)
http://www.vt4c.com/shop/program/mai..._id=2&hit_cat=
I have not heard anything bad about him (Chung?) and he responds to quote requests promptly.
Good Luck...and oh don't scratch that chassis!!
Old 6th August 2009, 08:44 AM   #15
Default xformers...
From what I see at their site Electra Print ships internationally.... you may want to check out using theirs.... http://www.electra-print.com/contact.php#ordering. Limiting to a single output impedance option betters performance and lowers price, worth looking into, That is what I have in my 45 amp. They sound amazing. Make sure to specify correct I limit for the trannies.
you may want to talk to this guy for chasis.... http://cgi.ebay.com/ws/eBayISAPI.dll...347wt_1167....
I must note that though I have dealt with and will again with Electra Print I have not with the chasis fella. But I am considering it.
As far as speaker sensitivity. earlier this year I setup a system with my Audio Electronics SE1 with 2a3 tubes in the (fairly large) living room , driving Sonus Faber 87dB speakers. It gets plenty of loud before hitting the distortion compression zone.
Old 7th August 2009, 03:25 PM   #16
diecast is offline diecast  United Kingdom
I can endorse EletraPrint - Jack Elliano is a good guy. Shipping to UK may be cheaper than you think - two custom OPTs for my SSE fitted in a single Flat Rate Box for US39 a little while ago. Takes PayPal.
For the chassis, once I worked out the layout, I got a 4mm anodised aluminium plate machined by:
http://www.schaeffer-ag.de/
They provide the layout software. Pricing is not too expensive and the finish is excellent. I mounted it on a wooden base (four sides to make a sort of open ended frame) and added an aluminium angle under the transformers to prevent sag.
Old 7th August 2009, 05:41 PM   #17
waam68 is offline waam68  United Kingdom
Philip at Bluebell has reasonably priced Hammond chassis...the steel are pre painted in grey or black & work well.
http://www.bluebellaudio.com/
Mike
Old 7th August 2009, 07:08 PM   #18
Seconded. Bluebell is mostly aimed at guitar amp stuff but is an excellent source of all things Hammond, including the 374BX (where I got mine) and some v nice hardware, switches etc (ditto).
Tubelab Simple P-P booangler Tubelab 669 23rd March 2016 04:37 AM
Electrolyticless Tubelab Simple SE nic6paul Tubelab 26 20th August 2013 12:56 PM
Second Tubelab Simple SE board done budmaestro Tubelab 0 24th July 2008 12:18 AM
Tubelab Simple SE & Edcor waam68 Tubelab 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubelab 14 27th November 2007 04:15 AM
Copyright 1999-2017 diyAudio
