Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th June 2010, 12:45 PM   #21
EWBrown is offline EWBrown  United States
EWBrown's Avatar
Adding extra windings whould not affect the other windings' voltage outputs. THe main consideration is to not exceed the toriod's total maximum VA capacity - which is fairly unlikely with most of these heavy duty Antek trannies.
The extra winding's voltage will drop somewhat under load, so plan on adding about 10-15% extra voltagewith no current load.
The other major consideration if you are adding a 5V rectifier winding, is that this winding will carry the fill B+ voltage, so insulate accordingly, use the aforementioned Kapton tape of similar, to prevent HV to chassis arc-overs.
ed B in NC
Old 13th June 2010, 02:08 PM   #22
TerrySmith is offline TerrySmith  United States
Also Antek toroids are rated for 50hz, which means you have more output at 60hz!
Old 14th June 2010, 12:17 AM   #23
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Sorry, of course you are correct. I was confused, and thinking about inductors in series on a common core. In that case, there is mutual inductance to consider and the total inductance of both windings in series is Lt = L1 + L2 +/- 2M (depending on whether they are connected in phase or out).
If the windings are not connected to each other, this isn't an issue.
Tubelab SE - alternate power transformerHide this!Advertise here!
Edcor Universal Power Transformer for Tubelab SE rknize Tubelab 43 19th June 2009 09:11 PM
Tubelab sse transformer wires newtube Tubelab 9 12th May 2009 01:29 PM
tubelab SimpleSe power transformer connection question dubdub Tubelab 10 12th September 2008 01:30 AM
tubelab SE 300b power transformer Dhoff Tubelab 27 14th March 2008 04:56 PM
Noob Power transformer for Tubelab SimpleSE dubdub Tubelab 9 4th February 2008 08:42 PM
