Simple SE grounding -- metal spacers/standoffs? - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th June 2009, 11:49 PM   #1
dogfish is offline dogfish  United States
Default Simple SE grounding -- metal spacers/standoffs?
I feel like if I thought about this hard enough I could figure it out...
I am starting my first tube build, a Simple SE. I'm going to attach the PCB to an aluminum top plate (in a wood chassis). I've read that I should use insulated RCA jacks (to prevent ground loops).
Question #1:
I was going to use conductive standoffs between the PCB and aluminum plate. Should I instead be isolating the PCB from the plate? Are the holes in the PCB (where the standoffs pass through) connected to ground, and if so, does it matter?
Question #2:
Should I insulate the transformers from the aluminum plate (via non-conductive washers)? Or is it OK that the transformer bodies contact the plate?
- Dogfish
Old 25th June 2009, 12:04 AM   #2
Ty_Bower's Avatar
I chose to use rubber washers to support the circuit board. They were less expensive than metal standoffs, easy to adjust for length, and offer some vibration isolation from the power transformer.
You may isolate the transformers if you choose, but the transformers themselves must be attached to the safety ground somehow. If there is a short between winding and core, there could be high voltage on an exposed transformer surface.
Old 25th June 2009, 01:04 AM   #3
Tubelab_com's Avatar
The holes in the PCB are not connected to anything, so metal mounting screws can be used.
The transformer bodies must be connected to the safety ground (the third prong on the power cord). This can save your life if a transformer develops an internal short (not common but it does happen).
In most cases I do exactly the opposite. There must be a connection from the amplifiers circuit ground to the safety ground. To avoid a ground loop, there should be only one such connection. I have found that the input connector is the best place for that connection if a metal chassis is used.
The wiring from the board to the input connector (including the volume control if used) makes the circuit ground connection to the chassis. I run a wire from the third pin on the power connector to the ground pin on one of the input connector. This makes the safety ground connection. If the transformers are bolted to the grounded metal chassis, they will get grounded.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 25th June 2009, 04:32 AM   #4
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I made standoffs by cutting long aluminum bushings into the lengths I needed. The holes on the board are sized for 10-32 screws.
Insulating the inputs does give you the choice of where to make the chassis ground connection, if your chassis somehow works better that way.
Old 26th June 2009, 05:26 PM   #5
Thanks for the help.
I've got everything I need (except the output transformers, waiting for Edcor). Now all I need is some free time!
Sources for enclosures, parts, standoffs, tubing, etc? rongon Tubes / Valves 8 29th July 2009 10:53 PM
Simple passive preamp. Neen some help in grounding. FaTTy Solid State 32 20th July 2007 07:10 AM
PCB standoffs ghisdal Class D 4 17th July 2007 11:25 PM
neoprene spacers gvy Planars & Exotics 0 9th January 2007 08:01 PM
Grounding Question on Simple System collinbd Multi-Way 0 30th November 2004 06:27 PM
Copyright 1999-2017 diyAudio
