simple se cathode resistor question - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 1st June 2009, 01:34 AM   #1
Default simple se cathode resistor question
I'm a little confused.
Can you run the simple se on different tubes (EL33/KT88 etc.) by just switching tubes (assuming that the power transformer is up to the task providing the correct B+ voltage) or do you have to change the cathode resistor for each tube type?
I've seen the chart on George's web site, I assume that you don't want to be in the red, and to choose a cathode resistor that is in the black.
I was also hoping to assume that I could just use the resistor thats in the parts list.
Thanks,
Paul
Old 1st June 2009, 08:19 AM   #2
Tweeker is offline Tweeker  United States
If your going to switch from EL34 to 6L6GC or KT88 yes you will need a different resistor if you want to run the higher dissipation (KT88, 6L6GC) tubes at full dissipation. You would also need a change to run tubes of significantly different mu.
Be sure your foil hat has a good low impedance ground.
Old 1st June 2009, 12:10 PM   #3
oldmanStrat's Avatar
Or you can be lazy like me and just use one resistor value for all of the tubes. It's not perfect for any one tube, but the 560ohm specified in the parts list works for all of the tubes for me.
You just need to make sure your B+ is close to the values in the table or you will have to take out the meters...
For security reasons my name is changed daily...
Old 1st June 2009, 05:28 PM   #4
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
At 450V B+, 560 ohm is a good compromise. It will run EL34s fairly hard, though.
Old 1st June 2009, 06:08 PM   #5
porkchop61's Avatar
I have a rotary switch with a different set of resistors depending on which tube I'm running.
I've seen some people add several resistors this way to fine tune the bias.
My SE amp schematic
Glenn
"Imagination is more important than knowledge"
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 05:11 PM
Determining cathode resistor bereanbill Tubes / Valves 5 28th April 2009 12:33 AM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 08:15 PM
Problem with cathode resistor liberty Tubes / Valves 3 9th September 2005 02:37 AM
Common Cathode Resistor D0Hbert Tubes / Valves 1 4th March 2005 12:42 PM
Copyright 1999-2017 diyAudio
