Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th June 2009, 03:17 AM   #31
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Looks good! I got all of my 45s off of eBay. They are all used, but most are strong. Some were bought in lots, other not. Got 1 or 2 duds, but the rest all work fine in the amp. I think I have a total of 7 or 8 usable pairs out of the bunch.
Old 27th June 2009, 12:50 AM   #32
oldmanStrat is offline oldmanStrat  United States
oldmanStrat's Avatar
more progress... mostly.
Drilled all of the holes for the xfmrs, and grommeted the wire entry.
Unfortunately when I was working on the tube holes, my el-cheapo harbor freight hole punch set gave up the ghost. You can see the screw on the top plate, bent quite a bit. What happened is that the cutting piece of the punch lost a couples of edges - looks like it was made out of cast iron. So when I was tightening it at some point it decided to bend rather than cut.
My intention was to use the small hole cutter to cut the big ones, since the screw for the larger diameter holes is so big, I can't find a drill bit large enough for the pilot hole! I may have to resort to using a dremel cutting tool to get my pilot hole started for the other three tubes.
This chassis is a lot bigger than it needs to be, but I purposely wanted this to be an easy build.
The only things unusual I have planned are hinges for the top plate and handles on the side for easy transport.
For security reasons my name is changed daily...
Old 27th June 2009, 12:56 AM   #33
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I busted two of those. I gave up and bought a Greenlee.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 27th June 2009, 01:01 AM   #34
rknize's Avatar
You get what you pay for at that place. Big, clunky steel things are usually fine and some of the tools and other supplies are OK. I needed an engine hoist and a 1 ton would have been plenty. I got the 2-ton, though.
Old 27th June 2009, 06:11 AM   #35
chrish is offline chrish  Australia
chrish's Avatar
Exact same thing happened with mine as well. Have since purchased better...
Old 27th June 2009, 07:11 AM   #36
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Originally posted by rknize
If you have a "real" electrical supply store, like for contractors and manufacturing, they will likely have it. There is a local surplus store near me that had boxes of used ones
In Chicago? Where?
Old 29th June 2009, 12:52 AM   #37
power xfmr and opts wired up & power switch. Also got the handles on the side of the box on. I think they are going to come in real handy.
My biggest issues are the holes for the tubes. I'll probably end up buying a hole saw and cutting a smaller than needed hole - and then use a bigger punch. You can see what a mess the small punch made of the gain tube holes. I plan on enlarging them and covering the holes with a metal mesh - the board sits low enough that the gain tubes won't come close to poking out of the top plate.
I have a few component subs to do on the PCB and wire up the volume and input jacks. I have some nice shielded audio cable in the office that I'll use for that.
I bought a hinge for the top plate, but that might need a degree of accuracy that me and my hand drill can't match. Wish I had a press...
Oh, and the wood block is temporary until I have worked out all the grounds.
Old 30th June 2009, 12:56 AM   #38
wired the input and vol pot up this evening... added a few missing grounds.... and powered her up.
No blown fuses.
B+ settled at 412 or so. B- was at -245, which has me a bit concerned.
Haven't popped in the 300b's yet or the gain tubes. I'll do that tomorrow, past the second beer mark and I know better than to be messing with this now...
I still have to find a piece of aluminum that is thick enough to attach to the heat sink. I thought for sure I'd have something around... guess I'll have to hit the local HW store for stock.
Old 30th June 2009, 01:24 AM   #39
Doc Jr 8156 is offline Doc Jr 8156  United States
Hello guys,
Excuse me but i'm ordering the boards tonight and I have 2 questions. First, Where is the parts list for the Tubelab SE? Second, I will use a choke for my Simple SE, what is the value? Thanks and pardon me. Godspeed.
John Revilla
Old 30th June 2009, 01:47 AM   #40
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Doc JR, here - http://www.tubelab.com/AssemblyManua...sLists_TSE.htm and 5H 200mA
*my* Tubelab SE build...Hide this!Advertise here!
Tubelab SE build and power supply questions. Binaural Tubelab 54 3rd March 2010 03:20 AM
Another TubeLab SimpleSE Build nic6paul Tubelab 91 13th June 2009 03:16 AM
Nubie first build Tubelab simple SE Mungo Park Tubelab 65 27th May 2009 05:41 PM
Long time lurker - first build a tubelab Simple SE cjkpkg Tubelab 59 21st December 2008 05:54 PM
Newbie wants to build Tubelab SE Monos. audiobliss Tubelab 12 19th July 2008 01:40 AM
