Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 2nd June 2009, 08:37 PM   #21
rknize is online now rknize  United States
All the best stuff comes from Chian
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I don't seem to have the P/N in my part list, but you want something for the TO-220 package type.
http://www.mouser.com/Search/Product...ap%2f4nOvM8%3d
Old 2nd June 2009, 08:43 PM   #22
oldmanStrat's Avatar
4724K-ND
its the kit with screws and shoulder washers.
For security reasons my name is changed daily...
Old 2nd June 2009, 08:58 PM   #23
PaulyT is offline PaulyT  United States
PaulyT's Avatar
Thanks! Ok, another stupid question: is there some reason not to use this to insulate the CCS ICs? Seems like the less high-voltage metal around, the better, for safety... but George didn't do this, why?
Old 2nd June 2009, 09:05 PM   #24
Not so stupid a question - I wondered the same thing. Looks like the tab is the anode which is connected to B+ - so that heat sink has some serious voltage on it.
I would think you could insulate it. you'll need shoulder washers too.
Lets see if Russ beat me to the punch again
Old 2nd June 2009, 09:10 PM   #25
rknize's Avatar
Most 3-terminal devices that have conductive cases for heat sinking tie the case to the center pin. This is just how the guts of the internal package are arranged. If you look at the spec of the CCS, the center pin is the input. If you look at the schematic, the inputs of both CCSs are tied to B+. So in this case, it's OK for the CCSs to "short-out" together on the heatsink. Georges PCB does not tie the heatsink supports to ground.
I think he is just taking the simplest road here. He does have you put insulators on the heater supply rectifier/regulator because it's not OK for those two packages to be shorted. You can insulate the CCSs if you want to make the heat sink safe. If that is your goal, you should also ground it for safety. I would also ground the FET heatsinks too, even though those packages are non-conductive.
Old 2nd June 2009, 09:11 PM   #26
rknize's Avatar
You win!
Old 4th June 2009, 08:04 PM   #27
its not if you win or lose, it's how you play the game :P
so now I'm in waiting mode for the power transformer to show up before I can do a checkout.
This time I'm going the simple hammond case route. it won't be pretty, but it should be a lot easier to mount connectors, switches, pots etc
Old 4th June 2009, 08:33 PM   #28
rknize's Avatar
I was in the same boat for a while while waiting for iron for the SSE. I found an old, umarked transformer that seemed to have 700VCT HT winding. PSUD told me that if I left off C4 I'd get a hair over 300V B+. Worked like a charm, except for the buzz coming from the Hammond choke. Ran like that for a month or two at least until the custom Edcor arrived for it.
Old 24th June 2009, 01:55 AM   #29
Ok, Russ asked me in another thread where I was with the build... so I was guilted into spending some time this eve on the SE amp instead of practicing my guitar
Yeah, it was torture.
So here is the planned inside of the chassis. I'm using a very standard aluminium chassis, with an optional grey ugly cage if I put it where normal people can touch it.
The idea is that I will put the PCB on standoffs on the bottom of the enclosure and cut holes for the tubes on the top plate. Since I didn't do anything special for PCB mounting under the chassis, the gain tubes probably won't poke out much. That's fine, because I planned this build to be more easy access to the board than an under chassis would allow.
Sort of taking George's Lexan amp to heart but using the standard hammond enclosure. I am considering hinges on the top plate... perhaps some gas shocks to open the hood. Ok, kidding on the last I can only imagine the amp toppling over with the weight of the xfmrs.
Old 24th June 2009, 02:14 AM   #30
and here is the top on with power xfmr and opt placement.
I'd considered putting the big AC cap on top, but it wouldn't fit under the cage.
Oh and this is a 300B only build ... of course it's possible I'll tear it down and do a 45. But I'm thinking I'd rather do a new amp for a 45 once I find the right tubes.
Tubelab SE build and power supply questions. Binaural Tubes / Valves 54 3rd March 2010 03:20 AM
Another TubeLab SimpleSE Build nic6paul Tubes / Valves 91 13th June 2009 03:16 AM
Nubie first build Tubelab simple SE Mungo Park Tubelab 65 27th May 2009 05:41 PM
Long time lurker - first build a tubelab Simple SE cjkpkg Tubelab 59 21st December 2008 05:54 PM
Newbie wants to build Tubelab SE Monos. audiobliss Tubes / Valves 12 19th July 2008 01:40 AM
Copyright ©1999-2013 diyAudio
