| Tubelab Discussion and support of Tubelab products, prototypes and experiments |
#11 |
Thank you nic6paul.
My simple se is now working and sounds great!!!! |
#12 |
Can not be un-usual that people get caps blown into pieces
when we think of the voltages used in tube amps. I am sure most tuube builders have been there? At least once or twice? Even me, have experieced this. Using only moderat 'transistor-voltages'.
lineup |
#13 |
Kerux,
Completely off topic, your earthlink dot net email address bounces when I try to return your contact about Electron Pools. Please send me a new one or call me at 425 823 2279. Bud |
#14 |
Yes, those 500V caps are running very close to their rated power with a 374BX transformer. I would suggest stick with a tube rectifier, do not use the standby switch option (an indirectly heated rectifier like the 5AR4 will give slow turn on) and use an inrush current limiter on the centre tap (just solder one leg of the current limiter to the centre tap wire and put the other leg in to the phoenix connector on the board).
Enjoy the new amp! Chris |
| Simple SE aux capacitor | hartze11 | Tubes / Valves | 8 | 10th June 2009 08:26 PM |
| Capacitor type for simple headphone amp | GianLorenzo | Headphone Systems | 3 | 20th December 2004 08:45 AM |
| Is there a simple capacitor matching method? | Sanaka | Parts | 9 | 8th December 2004 05:59 AM |
| Electrolytic capacitor woes in simple preamp | mattw | Instruments and Amps | 2 | 22nd September 2004 12:32 PM |
| simple capacitor-less amp | xocoatl | Solid State | 0 | 23rd April 2003 11:56 AM |
