Simple SE: ???Dumb Tube Rectifier question??? - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 29th April 2009, 12:42 PM   #1
BillEpstein's Avatar
Default Simple SE: ???Dumb Tube Rectifier question???
Jumper D1 and D2?
Screw terminals and board-mounted PSU an unaccustomed luxury to this half-fast kit builder.
Old 29th April 2009, 01:31 PM   #2
Tubelab_com's Avatar
Jumper D1 and D2?
NO ! That would put a short across the power transformer making it very unhappy!.
To use a tube rectifier simply plug in a rectifier tube. Remove the jumper (or open the switch) across the SW1 terminals.
If you plan to always use the tube rectifier and not use the solid state diodes, the diodes may be simply left out of the board. Leave the holes empty.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 29th April 2009, 07:30 PM   #3
Thanks George.
All I have left is finding a way (probably Plumbers Goop) to anchor 3- 20uF Aerovox caps and I'll have a 6550 powered Simple.
Too easy!
Old 30th April 2009, 12:35 AM   #4
chrish is offline chrish  Australia
chrish's Avatar
Cable ties might be useful for that purpose (if under chassis).
Old 3rd May 2009, 01:21 AM   #5
n_maher is offline n_maher  United States
Yup, you can even get zip ties with an eyelet built into the end.
Old 3rd May 2009, 02:38 AM   #6
My Aerovox caps are oval so through-hole mounting them is out. I used GE silicone caulk to tie them together and the group to one side and the bottom of the case. That'll hold and still be reversible.
How the heck do you post pix here? I've tried every combo of [img] and get nothing but the URL.
Old 3rd May 2009, 05:52 PM   #7
To have a pic appear in the body of your message, you need to put the file in your webspace or on a public picture server, and link to it. The disadvantage of this method is that future (years) readers may not see the pic if it has been moved or deleted from its location 'out there on the web'.
You can attach a pic using the 'Browse' button at the bottom of the 'Post reply' compose window, if it is less than 100k and of suitable size (800x...., 680 x ...). Limited to one pic per reply. Advantage: the image is archived with the diyaudio pages for future users to see.
Cheers
John
Mercury vapor rectifier tube question nhuwar Tubes / Valves 13 7th November 2009 10:31 AM
5Z4P rectifier tube question Burnedfingers Power Supplies 3 7th September 2006 12:58 AM
Question on shared rectifier / signal tube filament windings bst Tubes / Valves 2 7th December 2005 10:17 PM
rectifier tube question jtsjf Tubes / Valves 3 11th April 2004 07:03 PM
Simple bridge rectifier question. JoeBob Everything Else 51 15th February 2002 07:46 PM
Copyright 1999-2017 diyAudio
