Simple SE - one channel intermittent problem - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 23rd April 2009, 09:54 AM   #1
Default Simple SE - one channel intermittent problem
I have recently completed a Simple SE, and am very happy with it - I think I may have a problem though.
Intermittently one channel - always the same channel, will get quite distorted, and even almost completely so silent. This has happened every time the amp has run for more an hour or so.
Just now it was doing it (one channel extremely distorted), I turned the power switch off and back on, and all was fine (was off for barely enough time for the heaters to go out), and still is now......
Source is an iPod (headphone socket) as I haven't done a volume pot yet - I was hoping it was the iPod with a problem, but this latest occurrence makes me wonder..... all speaker connections are tight.
am using EL34, B+ 440V (Hammond 374BX), Rk 770ohm
any thoughts?????
TIA, Lee
Old 23rd April 2009, 11:29 AM   #2
Frank Berry's Avatar
Swap the EL34 tubes between channels. Does the problem follow the tube?
Frank
Old 23rd April 2009, 01:46 PM   #3
oldmanStrat's Avatar
trace the signal path from the bad channel - starting at the input. (swap L&R from the ipod)
Check cables, components (bad solder on the PCB?) - loose connections on the OPT's... It could also be a bad gain tube if everything else is fine.
For security reasons my name is changed daily...
Old 23rd April 2009, 03:34 PM   #4
n_maher is offline n_maher  United States
Default Re: Simple SE - one channel intermittent problem
Just an FYI, that is a horrible idea with tube amps, especially if your SimpleSE is tube rectified.
Old 23rd April 2009, 05:41 PM   #5
whitelabrat's Avatar
What's the mileage on your tubes? I'd also suggest swapping out the 12AT7 to see if that changes anything.
Old 23rd April 2009, 09:32 PM   #6
dubdub is offline dubdub  United Kingdom
I had the same problem and it turned out to be my ipod dying in one channel however the following possibilities should be considered:
1/bad tube
2/tighten up any conncectors/wires that are loose
3/tidy up internal wiring as best as possible
3/test the coupling caps, one might be bad
however, I find the problem is often the most obvious (bad tube is always 1 suspect)
Old 23rd April 2009, 10:11 PM   #7
Thanks for the tips - will start switching the input connectors today, although it hasn't played up since the on/off switching??
Is it usual/common for problems to occur intermittently like this??
Old 23rd April 2009, 10:19 PM   #8
Mileage - 3 weeks.....
Old 24th April 2009, 03:10 AM   #9
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Could also be a defective cathode resistor that opens when sufficiently heated.
Old 24th April 2009, 03:48 AM   #10
Tubelab_com's Avatar
Likely causes are:
Bad tube:
Swap the EL34's and see if the problem migrates to the other channel. Try another 12AT7.
Loose socket pin:
After the amp dies, CAREFULLY lightly wiggle each tube. If moving a tube fixes it, check the soldering where the socket meets the board, if OK, GENTLY squeeze each pin in the socket with a pair of tweezers so it grips the tube pins tighter. Some JJ EL34's had undersized pins.
intermittent solder connection:
Go over the board carefully.
Screw not tight on wiring terminal:
They have a way of losening in the first month after construction.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Luxman R-115 One Channel Intermittent DreadPirate Solid State 18 30th November 2016 05:26 PM
intermittent amp problem (PM80SE) jitter Solid State 18 15th June 2012 05:21 AM
Lanzar vibe 430 intermittent channel n2audio Car Audio 5 22nd August 2007 06:04 AM
BEZ T9B Intermittent problem redbullet Tubes / Valves 4 10th October 2006 03:32 PM
Intermittent PA amp problem pjpoes Everything Else 2 15th October 2005 11:36 PM
Copyright 1999-2017 diyAudio
