Tubelab SE 300B low level hum, help - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 30th March 2009, 02:25 PM   #1
abacus is offline abacus  Croatia
Unhappy Tubelab SE 300B low level hum, help
Hello
My Tubelab SE 300B amp have a low level hum, its barely to hear with my ears close to the speaker(5cm). It stays consistent regardless to the volume level. Volume pot case is grounded (blue Alps 100k), disconnecting the input wiring from the PC board no change. OPT James JS-6123HS, choke installed 6H, 200mA, changing PT orientation, no change. Tubes, Shuguang 300B-98B mash grid, rectifier Sovtek 5AR4.Any help about this problem?
And what grounding scheme will be the best to use, i used the first scheme from the Simple SE page.
Thanks.
Old 30th March 2009, 05:55 PM   #2
azazello's Avatar
You can try to put non elektr. capacitor 1 uf/65-250v parallel to choke 6 H.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 22nd April 2009, 05:19 PM   #3
I tried all possible combinations, cap across choke, separate filament transformer, 2 chokes in series, wiring and grounding combinations.
Nothing changed, hum is still there, anyone ?
Old 22nd April 2009, 05:57 PM   #4
Ty_Bower's Avatar
Maybe you have magnetic coupling between your power transformer and your output transformers.
Old 23rd April 2009, 02:14 AM   #5
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
What kind of chassis do you have? Did it always hum? My Tubelab SE on a bread board with no extra cap is dead quiet on my 98dB speakers. I am using a 10H choke and a 220uF final cap, though.
Old 23rd April 2009, 03:58 AM   #6
kevinkr's Avatar
Do you have ac or dc filament supply to the 300B?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd April 2009, 12:32 PM   #7
azazello's Avatar
Please, disconnect preapl. tubes /if there are interstages caps between stages/ and hear....
Old 23rd April 2009, 11:02 PM   #8
chrish is offline chrish  Australia
chrish's Avatar
Just keep your ears more than 5cm from your speakers and there is no problem
Old 23rd April 2009, 11:27 PM   #9
Tubelab SE hum shouldn't be audible even at 5cm from the speaker. I've had a loud hum problem but that was due to OP tubes I used at the time. Once I changed them, it became silent.
abacus, do you have another pair of 300B tubes that you can try temporarily?
Old 24th April 2009, 08:40 AM   #10
I have another pair of 300B tubes, but it is the same Shuguang 300b, i tried them with same result. Noisy tubes ? At the moment i don t have different 300B tubes to try. And moving PT away on long wires, nothing changes, hum is still there.
Changing 300B Tubelab SE to accomidate 50 triodes Binaural Tubelab 4 12th May 2009 03:56 AM
300b calibration (tubelab) wicked1 Tubelab 3 30th March 2008 04:04 AM
tubelab SE 300b power transformer Dhoff Tubelab 27 14th March 2008 05:56 PM
lesser of two evils, high level -> line level, digital volume control mazurek Solid State 3 19th November 2006 01:25 AM
Copyright 1999-2017 diyAudio
