Simple SE with KT88's - Page 21 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 21st May 2009, 01:11 AM   #201
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Hi
I really need to build this sweet amp
Considered lots of other options
ElCheapo, Darling, sex-amp, Decware, LadyDay, Seth/Horus etc
Even the new AudioNote Interstage 2A3/300B
Well, I still like the whole idea of SimpleSE, overall design, choise of tubes, build options, and not least the building instructions and support, it all seems to fit together very nicely
But when will I get started
sometimes we know very little, and sometimes we know too much
Old 30th May 2009, 09:40 PM   #202
Can anyone tell me the idea B+ for EL34's???
I have just switched resistors. With the 560ohm resistor. I was getting 490 on the B+
I just installed a 680ohm resistor and I am now getting 409 on the B+
If it needs to be lower I have a 750ohm resistor on hand.
TIA
Nick
Old 30th May 2009, 10:04 PM   #203
oldmanStrat's Avatar
Nikolas - where are you measuring B+ ?
B+ shouldn't change by changing the cathode bias.
George (Tubelab) has a chart that shows B+, OPT load & cathode bias resistor value.
http://www.tubelab.com/AssemblyManua...ormers_SSE.htm
First I would verify your B+ voltage.
For security reasons my name is changed daily...
Old 30th May 2009, 10:14 PM   #204
Hmmm.
I guess I didn't know what I was measuring.
The 2 yellow wires coming off the board measure 506v
The two red wires beside them are what measured 409v and 490v with other resistors?
Nick
Old 30th May 2009, 10:25 PM   #205
I'm not exactly sure what you are measuring either. Those are the wires coming from the transformer?
You don't want to measure B+ there. I'd measure it at the big choke where it connects to the motor run cap (if you have one).
Old 30th May 2009, 10:34 PM   #206
Seems like I forgot everything I learned since putting the amp together.
The amp is in the rig now.
I'll do some reading and relearn what I forgot and do some more measurments later...
Nick
Old 30th November 2009, 11:59 PM   #207
I JUST LOST EVERYTHING I WROTE!!!
So I'll make it short and sweet.
I just got my amp running again after parting it out.
THE PROBLEM.
When I go to flip the switch from Triode to UL. The amp sends a LOUD buzz to the speakers.
Anybody have any ideas?
Please let me know if you know.
Nik
Old 1st December 2009, 01:06 AM   #208
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
It makes this sound during the transition or it always buzzes in UL mode? Expect it to make a loud pop or scratch or other noise during the transition. Ideally, you shouldn't throw this switch while the amp is on (though admittedly I also do it from time to time). Your tweeters will thank you if you avoid it.
Old 1st December 2009, 01:12 AM   #209
It always made a pop or a scratch noise in transition before. But now its constant and its loud enough that I think it would damage my speakers if left on long enough.
I figure I must have something wired backwards???
Or could the UL taps be bad? The Opts are Transcedars and there Brand new...
Nik
Old 1st December 2009, 01:38 AM   #210
rknize's Avatar
So if you power up in UL mode, you get a buzz? My guess is that you wired the switch wrong and maybe leave the screens floating in UL mode? The screens should be on the common switch connection with the UL taps and the plate (via resistor) on either side.
Tubelab Simple SE with KT88's For Sale nikolas812 Swap Meet 3 26th May 2009 06:24 PM
2A3 or KT88 ? 6J7 Tubes / Valves 8 19th April 2009 12:52 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 02:20 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 11:05 AM
Copyright 1999-2017 diyAudio
