Simple SE with KT88's - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 26th February 2009, 12:18 AM   #101
korneluk's Avatar
- The 10M45 looks like it was installed OK.
- Did you line up the tube sockets such that the notch in the hole aligns with the notch on the silkscreen? Geoerge has a picture of this here:
Originally posted by nikolas812
Can you explain to me how to do this as if you were telling a 5 year old?
Put your meter in the ohms setting. Touch the leads together and it should read very close to 0 ohms.
Now, measure between T1-RED-YEL and the side of R4 closest to the edge of the board? What is the resistance in ohms?
Also, what is the rating of the fuse? How many amps, fast or slow blow?
Old 26th February 2009, 12:37 AM   #102
Yes the tube sockets were lined up correctly
Where do you put the red probe and the black probe? Does it matter. I get different reading each way. Neither stay the same. They change the longer I hold the probes on..
With the red probe touching T1- red yellow and the black the probe touching R4 closest to the edge it reads. Well. SOmething different every time. The last time read 2.512m some times it read 1.9 sometimes it reads 39.2 and it changes the longer you hold them on there..
I also have fast blo fuses. 1.6a and 2.5a
I have only used the 1.6a so far...
Nick
Old 26th February 2009, 12:48 AM   #103
korneluk's Avatar
Ooops! The KT-88 tubes you're using consume 1.6A each on the heaters alone, plus 2A for the 5AR4 rectifier heaters, plus .3A for the 12AT7, plus the B+ current draw.
You better get some 5A slow blow fuses and try again...
Old 26th February 2009, 12:52 AM   #104
OK.
Got some.
Here goes nothing....
Nick
Old 26th February 2009, 12:57 AM   #105
Blew it.
the 12at and 5ar4 started to light up then 5ar4 start flickering with blue and the fuse blew...
Nick
Old 26th February 2009, 01:02 AM   #106
korneluk's Avatar
...then 5ar4 start flickering with blue and the fuse blew...
Blue flickering means arcing due to excessive current draw.
Can you please check that capacitors C1 and C2 are installed with the right polarity - i.e. the (-) negative side to ground?
Old 26th February 2009, 01:04 AM   #107
There right.
Nick
Old 26th February 2009, 01:18 AM   #108
chrish is offline chrish  Australia
chrish's Avatar
THIS IS NOT GOOD ADVICE!!!!!
In a transformer, incoming power is equal to outgoing power (in an ideal transformer).
Power = Volts x Amps
Therefore Volts x Amps in = Volts x Amps out.
Your transformer is rated for something like 120 volts in, 750 volts out at 200mA, 6.3 volts out at 6A and 5.0 volts out at 3A.
750 volts at .2A = 1.25 Amps at the input
6.3 volts at 6A = 0.315 Amps at the input
5.0 volts at 3A = 0.125 Amps at the input
TOTAL = 1.69 Amps.
You should use a 2 or 2.5 Amp SLOW BLOW fuse.
Chris
Old 26th February 2009, 01:19 AM   #109
korneluk's Avatar
Nick,
Disconnect the auxiliary motor run cap and try again.
Old 26th February 2009, 01:21 AM   #110
korneluk's Avatar
TOTAL = 1.69 Amps.
Chris
Tubelab Simple SE with KT88's For Sale nikolas812 Swap Meet 3 26th May 2009 06:24 PM
2A3 or KT88 ? 6J7 Tubes / Valves 8 19th April 2009 12:52 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 02:20 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 11:05 AM
Copyright 1999-2017 diyAudio
