Tubelab SE input tube filament - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 24th January 2009, 06:48 PM   #1
Default Tubelab SE input tube filament
I took out the input tubes (5842) from my Tubelab SE for maintenance and put them back in. Turned it on and only the right side filament glows. I swapped the tubes but same problem so it's not the tube. Could it be a bad socket? The filament heater voltage comes from one source and splits left and right in this amp but if one side works fine and the other side doesn't, I'm guessing it's the contact problem locally or lack of. Any guesses?
Thanks in advance.
Old 24th January 2009, 08:20 PM   #2
Ty_Bower's Avatar
Maybe check for a cold solder joint where the socket is soldered to the board?
Is it the type of socket where you might be able to tighten up the contacts with a dental pick?
Old 24th January 2009, 11:41 PM   #3
I haven't thought of dental pick as a standard electronics equipment but now I can see why it may be useful. I used a toothpick (close enough) and now it works. Time to replace with better socket than those cheapo plastic ones (it's deformed little from the heat).
Thanks.
Old 25th January 2009, 12:10 AM   #4
Ty_Bower's Avatar
I used the nine pin "Fender style" sockets from TubeDepot. Ceramic base resists heat, and exposed contacts makes for easy adjustment should the need arise. Plus, they kinda match the style of the octal sockets I used. I've only had the amp running since last summer, but so far the sockets seem to be working just fine.
http://tubedepot.com/sk-9pinpcf.html
Weird old power transformers (filament, SS and tube) - $7 each! pjanda1 Swap Meet 6 29th March 2010 04:17 PM
Standard tube filament voltages and currents ilimzn Tubes / Valves 5 4th January 2010 05:53 AM
Input impedance of tubelab simple se pforeman Tubelab 1 24th May 2009 12:42 PM
Input impedance of tubelab simple se pforeman Full Range 2 24th May 2009 05:10 AM
Question on shared rectifier / signal tube filament windings bst Tubes / Valves 2 7th December 2005 10:17 PM
Copyright 1999-2017 diyAudio
