simple SE- almost there but right channel prob - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 3rd January 2009, 01:43 AM   #1
dubdub is offline dubdub  United Kingdom
Default simple SE- almost there but right channel prob
Hi
Im almost there with my Simple SE but I am having a problem with the right channel- from the speaker it emits a high frequency ring that can be heard when you put your ear to it the speaker and it is not as loud as the left speaker-it's not there when I dont have an ipod/cd player connected. Ive been having few problems with this channel-at one point it caused my el34 to 'pulse' a red cherry glow which cant be good. After checking and tidying the wires, it's stopped this and sound can be heard-but no as loud as the left channel.
Any thoughts on where I can look to sort the problem out? Any advice would be appreciated!
BTW it sounds great-I put an obbligato 70uf cap and it is very smooth in UL mode with feedback (have not tried tirode with out feedback yet)
Old 4th January 2009, 11:02 PM   #2
well- I found the source of the problem...my ipod! the cd player works fine but my ipod's right channel has given up the ghost-time tp get a new one methinks
When I swap over the valves (jj El34) from 1 channel to the other, one valve will glow red -but they are fine when they are in the positions they are in now-is this due to unmatched valves?
The amp is playing fine and sounding good! Pictures to follow soon in the photo gallery section/thread
Old 4th January 2009, 11:34 PM   #3
Ty_Bower's Avatar
The ringing sound and the pulsing red plates suggests to me that one channel is oscillating...
Old 9th January 2009, 02:17 AM   #4
Ty_Bower's Avatar
Glowing red plates are never a good thing. The design of the Simple SE is such that matched tubes are not necessary. Each tube individually self-biases due to the cathode resistor (R17/R27) on each output tube.
If the tubes appear to work fine when they are installed one way, but glow red when you trade their places, something is wrong. I'd carefully check the cathode resistors on the output tubes (R17/R27) and check the grid resistors too (R15/R25).
Carefully check your wiring between the board and the transformers to make sure you didn't accidentally swap a plate lead for a UL lead or something. Use your ohmmeter (amp should be off & unplugged) and make sure nothing is shorted to ground where it shouldn't be.
Simple SE - one channel intermittent problem astrodog Tubelab 15 25th May 2009 04:27 PM
When Volume up - left channel sound prob ? Krokotam_ Solid State 7 21st October 2008 03:55 AM
Simple technique for guitar amp channel switching? leadbelly Instruments and Amps 2 2nd September 2008 02:32 PM
Preamp, single channel ones? Think it will fix my prob? Help Lab_Rodent Parts 2 27th November 2007 11:59 PM
N-CHANNEL simple design ? B.I.G Solid State 15 6th July 2005 06:32 PM
Copyright 1999-2017 diyAudio
