Kaidee's Simple SE Build Thread - Page 8 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 4th January 2010, 06:38 PM   #71
@pchw .. my chassis is plexiglass, non conducting so I dont think anything is shorting, its basically like a wood panel that george uses on his website, I haven't made a proper enclosure or anything
Old 4th January 2010, 07:02 PM   #72
whoa.. it just hit me.. would running 1 channel with load (speaker) and the other channel without load cause the fuse to blow? cuz I've been testing with a single speaker...
Old 4th January 2010, 09:51 PM   #73
pchw is offline pchw  United States
In general, you don't want to leave the secondary open without any load because the primary will see an extremely high impedance (infinite) when there is is no load on the secondary. I am not sure it can be the cause of blowing the fuse, but it will harm in the long run for sure. If you only have one test speaker, you can use a 4 or 8 ohm 20W resistor on the other side. Otherwise, you can test one channel at a time by unplugging the KT88 that without speaker.
- Fred -
Old 4th January 2010, 11:26 PM   #74
Ty_Bower's Avatar
Originally Posted by nukaidee View Post
running 1 channel with load (speaker) and the other channel without load...
...is a bad idea. Just don't do it. If you are testing an amp, always keep an 8 ohm dummy load or a junk set of speakers connected to both channels. Running the amp with no load can result in a shorted output transformer - permanent damage.
Old 4th January 2010, 11:35 PM   #75
oh boy.. how can i test my opt for damage? but it was only 30 min..
Old 4th January 2010, 11:39 PM   #76
i just cleaned up the wiring, made sure everything is connected good, checked solder points AGAIN and threw in a new 5ar4 by a different factory. Will test again tonight. still have 2 fuses left =)
Old 5th January 2010, 12:00 AM   #77
Ty_Bower's Avatar
So, out of curiosity, what is the voltage across R17 and R27 while the amp is running? Is that voltage stable, or does it wander around a lot? I'm guessing if you are running KT88, you probably see about 40 volts across a 560 ohm resistor?
Old 5th January 2010, 01:35 AM   #78
might be my nickname is a clue, but what I'd be tempted to do, is go bigger on the fuse, see what burns and then fix it!! kidding, well kind of...
Wish I'd studied this stuff with as much interest 30 years ago!
Old 5th January 2010, 02:06 AM   #79
hey sparky.. i actually considered that.. just getting rid of the fuse and connecting an ammeter to it with my hands on the plug.. lol
Old 18th January 2010, 04:38 PM   #80
alright... fired it up again today. its been 20 minutes.. everything seems normal. hoping it was a bad 5ar4 that i was using and this one is okay now.. its glowing quite a bit though, like wayy brighter than the rest of the tubes....
My TABAQ Build Thread Consul Full Range 24 25th April 2016 11:04 PM
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 06:16 AM
Dan's Aleph Build Thread monarodan Pass Labs 19 14th February 2007 11:06 AM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 09:01 PM
Copyright 1999-2017 diyAudio
