Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 23rd January 2009, 07:27 PM   #241
chrish is offline chrish  Australia
chrish's Avatar
Actually, I thought the highest demand in a SE amp is when it is idling. If you are going to have a switch for resistors, you are better off putting them in the cathode circuit to get the valves at their best operating point, not the power supply. Another thing to think about is that the 5AR4 (GZ34) draws 2 Amps of heater current, while the 5U4G draws 3 Amps. So you will drop B+ a bit, but may end up increasing total transformer current.
Quite honestly, I think you might be spending a lot of trouble trying to fix something that ain't broke.
Old 23rd January 2009, 07:43 PM   #242
ChrisMmm is offline ChrisMmm  New Zealand
Oh? I was under the impression current draw was fairly constant regardless of input, but I still have a lot to learn!
Yeah, you are probably right. I just need to get used to the hot transformer.
Old 26th January 2009, 07:12 PM   #243
n_maher is offline n_maher  United States
Default 12ohm drivers
Quick question for the smart folks out there. This weekend I completed my new speaker project which uses drivers that are rated as 12ohm and I'm wondering how the SimpleSE will do driving these given that my output trafos have a 6ohm tap? Thoughts and opinions would be greatly appreciated.
Old 26th January 2009, 08:29 PM   #244
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Your maximum output power will be lower. Depending on the efficiency of the speakers, that may or may not be an issue. Distortion should be lower as well. I suspect it will work just fine for the most part.
Old 26th January 2009, 08:31 PM   #245
Thanks Ty, they certainly don't sound bad and power is not an issue - it's a near-field desktop setup.
YASSE - Yet Another Simple SE BuildHide this!Advertise here!
simple se build skipper Tubelab 151 2nd October 2009 12:47 PM
looking for simple speker build help colin.hepburn2 Full Range 19 20th September 2008 12:55 PM
a simple amplifier to build? testarossa2k Solid State 9 13th December 2006 08:30 PM
Copyright ©1999-2017 diyAudio
