Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 18th January 2009, 09:17 PM   #51
chrish is offline chrish  Australia
chrish's Avatar
Did you fit the solid state diodes to the board? If so, it may be worth checking that they are not destroyed. This is a common problem with the Simple SE. I would suggest removing the solid state diodes and purchase a new 5AR4. My JJ rectifier tube did the same thing, and the solid state diodes were destroyed. For me this was associated with the use of the standby switch. I removed the standby switch and the solid state diodes and replaced the rectifier tube (with a Sovtek 5AR4) and have had completely trouble free operation for over a year.
Old 18th January 2009, 09:49 PM   #52
DimZ is offline DimZ  Greece
no solid state diodes, no standby switch
as for the rectifier tube, I am waiting a sovtek on Wensday, and probably order tomorrow 1-2 more, I;ll check ebay first thing in the morning
next time I think I'll take a video of the fireworks (though I hope they dont happen), it was awasome and scary ....
Old 18th January 2009, 11:30 PM   #53
tubelab.com's Avatar
If you are in a 230/240 volt country a 1 amp fuse should be sufficient. I use a 2 amp fuse here in 120 volt land. The likely cause for fireworks is the rectifier tube itself. A larger fuse can make life really unhappy for things like transformers.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 19th January 2009, 06:46 AM   #54
i am in a 230/240 , I'll buy some 1A fuses, and test the amp again tonight, I'll try to find more rectifier tubes from friends and try them out ...
Old 19th January 2009, 02:21 PM   #55
removed the supl cap, with 1A fuse, no fireworks just sparks at about 15sec after switching - blown fuse
after 30 minutes with 1.8A fuse some sparks about 10 sec and more after 30 sec - blown fuse
tomorow I;ll get a gz34 from a friend and try it .... maybe its just the JJ
Old 19th January 2009, 03:23 PM   #56
If a new rectifier tube just sparked, it suggests that something else is wrong in the amp circuit. If it's the one that sparked previously, you don't want to use it anymore.
Old 19th January 2009, 03:49 PM   #57
update
I tried 2 more times to power the amp
1st time (1A fuse) sparks after 40-45 sec - blown fuse
2nd time (2.5A fuse) no sparks at all , after 2 minutes I turned on the cd player and played a cd, bad blury sound and lot of disortion ...... put a sacd - the same bad sound, and after 2-3 minutes of bad sound , a spark in the tube along with a pop and blown fuse
no more for tonight, I'll wait to get some more rectifier tubes ...
Evenharmonics - it has been the same rectifier tube , which Iam going to bury in the backyard ---- rip
Old 19th January 2009, 07:30 PM   #58
following a friends advice
1- removed the rectifier tube, powered on - el34 alive - no blown fuse
2- turned it off - put the rectifier back on - fired up - very little spark - no blown fuse - plays quite nice (not like the first time , but the motor run cap is out)
the 3d step was in case of a blown fuse at step 2 to change the rectifier tube - if it blew the fuse again then it wouldnt have been the rectifier but maybe the caps
anyway I didnt have to go to step 3 ....
is been playing like that for 30 minutes now - everything seems to be working ok ....... just not the sound of the first day ....
Old 20th January 2009, 01:47 PM   #59
just switched to another rectifier tube (5U4gb) .... no sparks and everything ok
no JJ anymore for me ..................
46 and the Tubelab SE w5jag Tubes / Valves 8 18th May 2009 08:52 PM
tubelab PP? weinstro Tubes / Valves 9 25th March 2008 04:07 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubes / Valves 24 30th July 2006 04:39 PM
tubelab ethermion Tubes / Valves 24 20th July 2006 04:13 PM
Page generated in 0.10885 seconds (76.46% PHP - 23.54% MySQL) with 11 queries
