Go Back   Home > Forums > > >
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 12th January 2009, 09:44 AM   #41
DimZ is offline DimZ  Greece
things going a bit slow, but with two liitle kids and full time job, I dont have enough spare time ..... (all metalwork and most of woodwork done by me ....)
heres another one
Old 12th January 2009, 09:45 AM   #42
and a detail from underneath
Old 12th January 2009, 08:38 PM   #43
today was a busy day ..
Old 12th January 2009, 08:40 PM   #44
still .. work to be done
Old 18th January 2009, 01:02 PM   #45
today the simple se said his first words ...
first of all he is dead silent
I;ve only listened him for a couple of hours with triode mode and not in high volume (kids are sleeping)
the sound is just amazing (my poor English dont help me to describe what I heard)
never believed that my first build would be so good ...
ty George and the rest of you for your advices ....
Old 18th January 2009, 01:05 PM   #46
later I will try ultralinear,feedback, the EL34's and of course higher volumes .....
still cant believe it .....
Old 18th January 2009, 03:39 PM   #47
oooops,
suddenly a strange noise came out from one channel, i turned it off for 10 minutes and when i powered it again there were sparkles in the rectifier tube and a blown fuse .... replaced it and happened again ...... no more fuses left so I have to wait untill tomorrow to get some more (probably bigger ones , 5A instead of3)
any ideas for the sparkles ??
Old 18th January 2009, 03:57 PM   #48
Evenharmonics is offline Evenharmonics  United States
I wouldn't use 5A fuse. It sounds like power capacitor may be at fault. There was a mention of this symptom on older thread here. Try search function with "simple se fuse".
Old 18th January 2009, 04:03 PM   #49
to be more accurate the sparks were more like fireworks ...!!
by the way i'll search for similar issues ..thanks
Old 18th January 2009, 08:04 PM   #50
Ty_Bower is offline Ty_Bower  United States
Ty_Bower's Avatar
Don't use a 5 amp fuse. Don't use a 3 amp fuse, either. 2 amp fuse is plenty. If something is wrong, you want the fuse to blow.
Your 5AR4 rectifier tube is done. It has arc'd out, and will never be good for vacuum tube service again. You will need a new rectifier tube.
There may be rumors floating around that JJ rectifiers are not particularly well known for their durability. Lots of early failures and that kind of stuff. I'm running an older Sovtek in my Simple SE right now. I bought it about ten years ago. I've also used Chinese 5AR4 in my Simple SE with success. Maybe they were Shuguang, or maybe they were Sino. The label on the side said "Ruby".
Old 5AR4 made in Gt.Britain and Japan (Philips, Mullard, Matsushita) are well known for their reliability, but they tend to command very high prices in the used market.
tubelab seHide this!Advertise here!
46 and the Tubelab SE w5jag Tubelab 8 18th May 2009 07:52 PM
tubelab PP? weinstro Tubelab 9 25th March 2008 03:07 AM
Especially for Tubelab: 845 amp 2.0 Giaime Tubelab 24 30th July 2006 03:39 PM
tubelab ethermion Tubelab 24 20th July 2006 03:13 PM
