#21 | |
#22 |
If you decide to go the Allied route, don't forget to grab your Triad C-14X choke from them too.
#23 |
If you are in Greece, your mains voltage will be 220-230volts, so I don't think that cheap Allied transformer would work as I think it only has primaries for 110-120 volts.
#24 | ||
374BX & 193J Choke from AES: $142.00 6K7VG & C-14X Choke from Allied: $62.00 That's a significant price difference. Not sure what to do. Quote:
#25 |
For interest, I am using the Hammond 193H 5H 200mA choke and have zero hum on my 92dB speakers.
#26 |
apart from hammond is there any other brand that I could use (220-203 V)?
#27 |
so it is
KT88 hammond 374BX hammond 193J hammond 1628SEA and 5AR4 would this compo be fine or is it too much ??? and could this work with other tubes as well (such as 6550 or el34)?? |
#28 |
Sounds fine to me. Almost exactly what I am doing. It will work fine with 6L6GC and EL34's as well. In fact, I'd drop in a set of cheap Chinese 6L6GC's when you first turn it on to make sure everything is working "just in case".
#29 |
1 X hammond 374BX
1 X hammond 193J 2 X hammond 1628SEA TOTAL (with shipping - found them in Germany)) about 440euro ... quite much ... (shipping is 45 euro) |
#30 |
as George told me the hammonds are good but he prefers edcor better, so no hammonds for me
three options left 1. Edcor CXSE25-8-5K 2. Transcendar 5k- 8 ohm 10W wit UL tap 3. Transcendar 5k- 8 ohm 15W with UL tap with taps for both 4 ohm and 8 ohm edcor or transcendar ?? btw, the pcb's arrived yesterday (ty George) and the stuff from digikey ..... |
| Thread Tools | Search this Thread |
| 46 and the Tubelab SE | w5jag | Tubes / Valves | 8 | 18th May 2009 08:52 PM |
| tubelab PP? | weinstro | Tubes / Valves | 9 | 25th March 2008 04:07 AM |
| Especially for Tubelab: 845 amp 2.0 | Giaime | Tubes / Valves | 24 | 30th July 2006 04:39 PM |
| tubelab | ethermion | Tubes / Valves | 24 | 20th July 2006 04:13 PM |
| Page generated in 0.09780 seconds (78.50% PHP - 21.50% MySQL) with 11 queries |
